HID FOGS! Yellow H3
#41
Originally Posted by CanadianMoFo
I don't mean to state the obvious...but the bulbs have to be absolutely clean when they go in otherwise they'll burn out quickly. If you've accidently touched them with your finger clean them up with an alcohol wipe. You can also try a super clean microfiber cloth.
While installing the bulbs you need to be careful the glass bulb itself doesn't scrape against the housing and either get scratched or pickup some grease.
CM
CM
Id like to fix this problem rather then do a retrofit to HID, im happy with halogen in the fogs...Id be happier if they stayed lit on the passenger side.
As far as upgrading the fuse...does this mean there is a seperate fuse for either side? The socket still works, I mean, if the fuse was blown wouldnt you get no power from the socket?
I don't know what it is, but im not putting expensive H3s in anymore until its fixed, i guess i can live with burning out cheap oem bulbs.
#44
Originally Posted by swowlinc
hey, so what size bulbs go in the corner lights? Do you have to take off the bumper for that?
ps... I have these in my tags and reverse lights[img]www.eatools.com/~luke/ledlight/194-1hw-2.jpg[/img]
#45
GOT MY YELLOW H3 HID's BUT.........
Do they fit. I bought them in a GD, and I dont think they will fit in the stock housings. Can someone who has done lots of Fog work and HID's shed some light on this. If they work, do I need to modify anthing to make them fit? I thought we needed H3 Mini's??? See pics attached.
#46
I know the larger halogen H3's (different manufacturers make different shaped bulbs on the same base) as well as the newer mini-H3's will fit. However I can't shed too much light on wether the HID style will fit. I heard that there is lots of room for the larger H3's to fit.
You should just be able to pop one in there and see if it works or not. Just wire it directly to the battery at the drivers side.
CM
CM
#47
Wait...I thought you already bought and installed these. Am I missing something?
http://forums.maxima.org/showthread.php?t=480716
#50
Guys guys guys, to get to and change the fogs or blinkers is really simple (and very clear in the stickies)
http://forums.maxima.org/showthread....=1#post3734123
"For the driver's side you need to remove the intake or the stock air filter. This will give you access to the bulb. For the passenger's side, remove the fluid reservoir (there's 2 10mm bolts holding it in place). After that you'll need to remove the fill tube for the windshield washer fluid. You can do this by twisting it counter clockwise. After that you should have access to the bulb"
Simple as that and have done it plenty of times! I have also taken off the bumper to remove the lenses and it's pretty easy as well but just unecessary labor!!
I don't know too much about the HID style fogs but mt first set of Piaa H3's ($60) lasted me for a year and a half and I have them on pretty much all the time.
#51
Just stuff them in and your good to go.
Kamski
#53
Originally Posted by kamilkluczewski
They FIT!! I have the exact same ones, they fit without a problem.
Kamski
Kamski
#54
They are there, its just they have a foam protector around them, which fits snuggly over a case that covers the bulbs. See pics above.
VQ
PS I will have the install and pics up on Sat. I will do a step by step. TO make a sticky!!
VQ
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
Calabar
10-05-2015 09:57 PM
