Technosquare ecu DYNO....
Old 05-12-2006, 08:18 AM
  #401
Monotaur's Avatar
Originally Posted by RHMax
5AT and 5AT w/ TCS are available, as well as 6MT w/ TCS. For 4AT, 5AT w/ VDC, and 6MT w/o TCS are not available yet. 6MT w/o TCS is probably not compatible 6MT w/ TCS, but you can check with them.
Ok, so is the 5SP AT without VDC and without TCS available? My early 2004 has neither... sorry to beat a dying (dead?) horse. I'm not sure if by saying "5AT" you mean "5AT with TCS but without VDC" or just the 5AT by itself, since in later cars you got one or the other.
Thanks.
Monotaur is offline
Old 05-12-2006, 09:04 AM
  #402
Newbie just Registered
RHMax's Avatar
Thanks.
Yes 5AT by itself, no TCS or VDC. You're good to go.
RHMax is offline
Old 05-12-2006, 10:27 AM
  #403
Monotaur's Avatar
Awesome, thanks!
Monotaur is offline
Old 05-12-2006, 02:33 PM
  #404
Nations 1st 6th Gen Turbo
chernmax's Avatar
You're going to roll to So Cal? You can just send your ECU in with your current AFR or dyno sheetw/ AFR. He send send it back to you next day.
Oh, my bag, I thought Teh had a dude up near NY that would do it, regardless, my wife is going to the Philippines for a month with my daugter next month, I can drive her SUV while I wait...
chernmax is offline
Old 05-12-2006, 05:05 PM
  #405
my rear view mirrors flap like a f-ing bird
Tek-Niq's Avatar
make sure you call and get my program, cause he'll give you the simple program I had at first wich you will loose the low end TQ with...
just make sure he knows wich program to give you before you send it..
Tek-Niq is offline
Old 05-12-2006, 06:16 PM
  #406
RHMax's Avatar
I don't think that's a problem. He kept saving over the old file when he was doing my car.
RHMax is offline
Old 05-12-2006, 06:46 PM
  #407
Tek-Niq's Avatar
max blue just sent his and he lost his low end TQ, he told me he can't even spin the 20's that are on the car...
he might of gotten the last program... just make sure, cause my car spins the 22's on dry pavement easy
Tek-Niq is offline
Old 05-12-2006, 10:45 PM
  #408
RHMax's Avatar
What other mods does he have?
RHMax is offline
Old 05-13-2006, 10:30 AM
  #409
Tek-Niq's Avatar
intake, exaust that I know of..
Tek-Niq is offline
Old 05-16-2006, 08:44 AM
  #410
chernmax's Avatar
Tek, whats the web site or contact info for TS, I want to send mine.
Do I have to let him know
Injen CAI
Pully
Y-Pipe
Greddy SP-II
chernmax is offline
Old 05-16-2006, 02:46 PM
  #411
greg hazlett's Avatar
Those are also my mods, I will be very interested to see the results! I will wait for the better price though..
greg hazlett is offline
Old 05-16-2006, 02:58 PM
  #412
RHMax's Avatar
Injen CAI
Pully
Y-Pipe
Greddy SP-II
The mod info is good, but if you can get him your AFR print out (from dyno), it would be better since some mods change your stock AFR.
RHMax is offline
Old 05-16-2006, 04:20 PM
  #413
chernmax's Avatar
Well I guess I need to get a dyno first. Question? should I disconnect the battery first to clear out any ECU recalibration because of my mods or just get a straight up Dyno???
chernmax is offline
Old 05-16-2006, 04:22 PM
  #414
chernmax's Avatar
Well my engine cover graphic work cost more than an flashed ECU and I gained 0-hp as a result. Need more power...
chernmax is offline
Old 05-16-2006, 06:44 PM
  #415
RHMax's Avatar
I would. I think it would be a better comparison point for after.
RHMax is offline
Old 05-17-2006, 02:50 AM
  #416
Must be nice Big Bank Hank!
Old 05-17-2006, 03:06 PM
  #417
Tek-Niq's Avatar
Injen CAI
Pully
Y-Pipe
Greddy SP-II
http://www.technosquareinc.com/index.html
you have to print out the mail sheet on the site, that has the mod list box in it...
just call them to make sure you get my program thats all..
Tek-Niq is offline
Old 05-17-2006, 06:19 PM
  #418
chernmax's Avatar
As always, thanks bro...
chernmax is offline
Old 05-18-2006, 02:25 PM
  #419
GrandPa
ramberg's Avatar
I did a dyno yesterday.
220.77 whp
227.74 Max. Torque
I will post the run files tomorrow. My scanner is not working.
ramberg is offline
Old 05-18-2006, 05:36 PM
  #420
RHMax's Avatar
220.77 whp
227.74 Max. Torque
What was it before?
RHMax is offline
Old 05-18-2006, 06:10 PM
  #421
And what mods?
Old 05-19-2006, 07:25 AM
  #422
GrandPa
ramberg's Avatar
Dynojet Research Inc.
Run Name: C:\DynoRuns\Nissan\536498\RunFile_001.drf
Run Title: Warren 1st
Run Notes:
Run Date: 5/17/2006 8:49:16 AM
RunFile_001.drf: 71.27 °F 29.59 in-Hg Humidity: 47 % SAE: 0.99 Average Gear Ratio: 66.68
s RPM x1000 hp ft-lbs
0.27 3.10 115.61 195.64
0.53 3.20 122.50 201.05
0.77 3.30 124.45 198.07
0.96 3.40 128.84 199.02
1.15 3.50 133.54 200.39
1.34 3.60 138.43 201.95
1.53 3.70 143.41 203.58
1.73 3.80 145.58 201.21
1.94 3.90 146.96 197.92
2.12 4.00 151.22 198.56
2.29 4.10 159.85 204.77
2.48 4.20 165.88 207.43
2.69 4.30 173.48 211.88
3.25 4.40 186.40 222.49
3.45 4.50 192.82 225.05
3.63 4.60 196.65 224.52
3.81 4.70 199.78 223.25
3.98 4.80 201.66 220.65
4.17 4.90 206.63 221.48
4.35 5.00 209.45 220.02
4.53 5.10 212.44 218.76
4.71 5.20 212.94 215.07
4.90 5.30 213.47 211.61
5.08 5.40 216.01 210.06
5.27 5.50 215.95 205.79
N/A 5.60 N/A N/A
5.67 5.70 218.45 201.95
5.87 5.80 217.79 197.36
6.07 5.90 218.83 194.84
6.28 6.00 217.98 190.81
6.50 6.10 220.32 189.70
MAX: 6.50 6.10 220.32 225.05
MIN: 0.27 3.10 115.61 189.70
I needto get a meter to tune it. Fuel mixture was getting to lean.
I had the same mods as last time. I did not have the run files last time. But the whp was about the same.
ramberg is offline
Old 05-19-2006, 11:55 AM
  #423
dot dot dot ...
NmexMAX's Avatar
Runfile to bizzy1999@hotmail.com
NmexMAX is offline
Old 05-19-2006, 12:28 PM
  #424
Apollos2's Avatar
Tek, wouldn't they give all the 6th gen Maximas your program? Especially since the generic flash seems to have issues.
Apollos2 is offline
Old 05-19-2006, 12:51 PM
  #425
Tek-Niq's Avatar
thats what I thought until a member did it and didn't notice anything, I belive he has the lean program I had before the new one, thats why I say make sure..
Tek-Niq is offline
Old 05-19-2006, 06:04 PM
  #426
maximob's Avatar
OK...so I love the idea of ECU tune, but I'm kinda attached to my warranty still. Is there any way to increase fuel just a little? like maybe increasing fuel pressure?
sorry if that's a stupid question, but I'm working on my edumacation...
maximob is offline
Old 05-19-2006, 06:31 PM
  #427
RHMax's Avatar
Increase fuel requires remapping. Dealership probably won't know the ECU is reflashed, since it will still retain the same version number; unless someone actually check the codes and values.
RHMax is offline
Old 05-20-2006, 04:22 AM
  #428
Tek-Niq's Avatar
my dealer said if I get a CEL they won't clear it for free under warranty cause its aftermarket, but they are the ones who installed it the first time for me..
Tek-Niq is offline
Old 05-20-2006, 05:33 PM
  #429
maximob's Avatar
What's a CEL?
maximob is offline
Old 05-20-2006, 06:06 PM
  #430
cwepruk's Avatar
Check Engine Light
cwepruk is offline
Old 05-21-2006, 12:35 AM
  #431
chernmax's Avatar
I can erase my CEL with my OBD-II, If you went to any Autozone, Autobacs, etc and got a free ECU fault code reading, couldn't you ask them to also hit the erase button??? That turns off the CEL light...
chernmax is offline
Old 05-21-2006, 06:50 AM
  #432
Tek-Niq's Avatar
sure why not, but for peace of mind, mines hasn't given me a CEL yet..
Tek-Niq is offline
Old 05-21-2006, 07:11 AM
  #433
6thGenMax's Avatar
i should get alot out of this ecu because just with the berk intake i got 219whp 232tq im going to call bryan over at berk to send me back my run file i lost it in my last computer crash
6thGenMax is offline
Old 05-21-2006, 08:45 AM
  #434
chernmax's Avatar
That's cool, I also meant just in case, that the dealer is not the only option for clearing a CEL light...
chernmax is offline
Old 11-29-2006, 11:15 PM
  #435
madmik's Avatar
Just got the CE y-pipe on Monday and the TS ECU. Monster gains. Had some pinging so I backed the timing with my software. I saw some old codes (this is a spare ECU I bought) and cleared them at the same time. D*mn, SES light came on after 30 minutes of driving: P0171- compensation too high for system lean condition (too much air or not enough fuel pressure).
Checked that everything is tight and no exhaust leaks (O2 sensor is ok). I figured by now that TS whould have resolved all lean conditions with all the dyno time Tek did.
Got old ECU back on to see if Y-pipe or ECU is culprit. 3 trips and no SES. I will drive a few more days, clean the MAF and get TS ECU back on. A spare ECU is worth it-$125 www.car-parts.com - must match the model printed on ECU. Mine is MU A56-X50.
madmik is offline
Old 11-30-2006, 09:30 AM
  #436
dot dot dot ...
NmexMAX's Avatar
What software?
NmexMAX is offline
Old 11-30-2006, 10:10 AM
  #437
RHMax's Avatar
I did't get any pings or SES when I put the y-pipe in.
RHMax is offline
Old 11-30-2006, 10:41 AM
  #438
DeusExMaxima's Avatar
I have slight pinging sometimes and I have no SES. I figure if you splash it with 100 octane, pinging will go and u get more power.
DeusExMaxima is offline
Old 11-30-2006, 10:50 AM
  #439
dot dot dot ...
NmexMAX's Avatar
Pigning could mean a lot of things. Can any of you monitor A/F (with an upstream wb) and/or timing?
NmexMAX is offline
Old 11-30-2006, 12:39 PM
  #440
madmik's Avatar
When TS cloned the immobilizer to the second ECU, they copied everything: IMMO code, VIN, and the extra +2 advance I had manually added. I use Sunoco 91. I played it safe with the TS ECU and went to -2. Pigging stopped. Will try 93 and adjust.
I use Autoenginuity. I got over 30 minutes of RPM, A/F, intake temp, timing, and other sensor data with TS ECU. The O2 1 sensors were reading .14 - .95 (range is 0-2.55V). Have to do some reading on this.
Got to record a baseline with Y-pipe only. I did not keep previous runs to compare what is happening. Also got to check if MAF is reading within specs. Neat tool. Others may be better but its really usefull.
madmik is offline
Quick Reply: Technosquare ecu DYNO....
