VAFC vs. SAFC
VAFC vs. SAFC
Vafc Is Only For Honda And Acura. It's Made A Car With Vtec.
Um... Nissan Cars Don't Have Vtec. I Wanna See How You Gonna Use This Vafc. If You Already Bought This Product And Was Planning To Use It On Nissan Car. Good Luck. I Noe You Gonna End Up Returning That Product.
Let's Say It Was Vafc Was Better Like U Said. How Come None Of Fixed Up Supras And Skylines Have It??? Dat's Right It Only Wokrs With The Cars With Vtec.
Safc Ii Is The Way To Go Man.
Don't Ever Post Something Stupid Like Dat In Da Future.. Thank You.
Then I suppose I have installed VTEC on two different Maximas now.
As for the original poster: Of course you will notice a difference performance wise with the cams, I cant speak for nismo/stillen cams or any other cams for that matter, I just purchased my first Nissan and Im still new to the field of VQ's and Nissans in general, but I know on most other cars, along with the purchase of cams, you will need some mild tuning to get the idle right among other things. I would hate for your idle to go to ****.
Good Luck.
Originally Posted by BlackMax06
A VAFC will control any motor that has variable valve timing. All that little nifty device allows you to do is control the point at which it occurs (like on a honda, instead of vtec at 6000, you can change it to 4800, trust me I know, I just sold my turbo integra.) .
Aiite. You Can Install It But Withought Connection Vtec Solenoid Wire. Cuz That's The Whole Point Of Having Vafc. I Have Two Constant Adjustable Valve System. It's Totally Different From Vtec. I Have Two Lobes On My Cam. Vtec Has 3. Vtec Uses The Solenoid To Change Oil Flow To Other Direction To Enable Vtec.
So Without Connecting The Vtec Solenoid Wire, It's Identical To Safc. Vafc Ii Also Allows For The Vtec Engagement Point To Be Manipulated From 3000-7000 Rpm, Including The New I-vtec Systems, Vafc Has More Functions, Because It Have Vtec Engagement Point Change And Unmatch Fuel Control..
Ok Sr20den.
Let Me Ask You This.. How Do You Hack Afc, If I Have Different Injectors?
Ok Sr20den.
Good Luck.
Good Luck.
and VQ advance your timming with cam angle wire you are running
so VAFC Vtec fuction won`t work on *^&%$ nissan cars. y won't they use vafc cuz it don't work.
like i said.. you can install it but it's gonna be identical to SAFC. believe wut you want. and do wut u guys want. it's just an opinion. i am not trying to fight here. just trying to help. if i wasnt much of a help then my bad.
take care.
Tom
Ok Sr20den.
Ok Sr20den.
With four million posts on maxima.org you would think there would be a wealth of information here for you to search through and find for yourself.
http://forums.maxima.org/showthread....hlight=VAFC-II
http://forums.maxima.org/showthread....ighlight=vafc2
http://forums.maxima.org/showthread.php?t=449929
There is A LOT of PWN4G3 in this thread:
sure this link is already mentioned, but it's at the top of General Max Forum:
http://forums.maxima.org/showthread.php?t=433879
(Dude, do you really hit SHIFT for every word, or are you trying to type in Caps Lock for some weird reason??)
Originally Posted by Glude
So am I the dumb guy who wants the VAFCII?
I AM SAYING YOU ARE DUMB. IF YOU WANNA BUY IT AND INTALL IT FEEL FREE. I JUST GAVE MY OPINION ABOUT VAFC VS. SAFC.
I STILL DON'T GET WHY SOME PEOPLE WANNA GET VAFC OVER SAFC FOR THE NISSAN CAR. V IN VAFC DOESN'T RING A BELL TO YOU GUYS?
ANYWAY. I ALWAYS LIKE TO WRITE CAP. SO I ALWAYS HAVE CAPS LOCK ON. I ALSO DO THIS ON MY ESSAYS AND ETC. ALWAYS GET IN TROUBLE THOUGH. YEAH IT'S WEIRD REASON I GUESS.
You dont have any place for calling me dumb but whatever, Im not the one making myself look like a complete idiot. I woud prefer the better of the 2 afc's for tuning if they cost the same price, wouldnt u? Stop yelling
Nations 1st 6th Gen Turbo
Be cool and turn the caps off, it's annoying. Sometimes it's not what you say, but how you say it that will get you heard...
i dont see any of you pu$$y *** bitc*es dishing out the doh to try new things out just to benefit others on the forum. all your doing is *****ing at my friend here.
after reviewing your links, the only difference that i have found b/t the safc and the vafc is the 12 more points for fuel, and a vtec engagement switch.
i highly doubt that there is a huge difference by engaging the butterfly valve a little earlier. what like a 1 or 2 hp difference.
Y DONT ALL OF YOU JUST ATTACH A STRING TO THE ****ING VALVE AND OPEN IT YOURSELF FROM THE CABIN, YOU'LL SAVE HUNDREDS OF $$$$.
SR20 what have you contributed to this forum except the "wasting of time"
do you have an SR20
i currently have a s14 sr20det along w/ a max and a xterra.
so i do believe i know what i am talking about. not to mention "eric" my buddy to also posted on my friends sn "SEXIMA" have worked for race shops, and have done countless modifications ranging from your POS EG to you W202.
if you have anything that i wouldn't know please enlighten me. but dont post up "VAFC>AFC" explain yourself in the same post. man...had to read all those stupid posts just to find out 2 lil things.
WASTE OF FUC*King time. people say u know ur ****.....PROVE IT. DONT PROVIDE WORTHLESS LINKS.
MAN...i g2g study for midterms....
JUST BECAUSE YOU POST ALOT DOESN'T MEAN U KNOW YOUR S*IT.
Originally Posted by AzNx2k2xSEXima
actually ur not in the right place to call people dumb. i believe that my friend sexima 04 was the first of alot of things in the 6th gen max's.
do you have an SR20
do you have an SR20
AzNx2k2xSEXima
what does any of this have to do with you? your sexima friend (nice names) came on here calling names and proving his ignorance saying
he was proven wrong. it makes no sense and is disproven by those with the VAFC on their Nissans. HE IS WRONG.
VAFC has a V and only works with VTEC
Originally Posted by NismoMax80
AzNx2k2xSEXima
Originally Posted by logik05se
nissan uses continuosly variable valve timing system, except we call cvtcs, and honda calls it vtech. correct me if im wrong but arent they pretty close to even the exact same thing?
but there is a huge difference between the honda vtec and nissans cvtc.
THE BIGGEST difference as stated b4 in the thread is that honda's vtec actually switches CAM LOBES. creating the best of both worlds. conservative at low RPM and real aggressive at high. the whole thing is controled by a solinoid that switches the heads...dang...can't eplain.....need to draw it out. but the NISSANS ONLY switch the timing of that cam and they added the lil butterfly valve in the manifold which seems to be the WHOLE PURPOSE for using the VAFC. this didn't give me any gains when i was messing around w/ it. THIS is no where comparable to REAL VTEC.
i was kinda pissed off that u guys were harassing my buddy. He isn't too fond of this forum in the first place. Not to be *****ing at u guys but u 6th gens need to man up and start testing out more ****.
DONT TALK ABOUT HAVING A JOB and no time. We didn't pull money out of our asses to be able to do all the mods. we have jobs too. so thats no excuse
Your a F*cking idiot, I have nothing more to say. You obviously have no clue what your saying here because the people you are attacking have contributed more to the forum than your butt buddy ever will.
my friend already has contributed quite a bit, just by being tough enough to try new things out instead of being a little pus$y and making up reasons y not to do this mod.
dude....did you NOT read what i said..... JUST BECAUSE you have alot of post duzn't mean u know all your sh*t.
Point missed again. Please revert back to statement #1.
do you have an SR20
I did however provide the links that showed where this information had been repetitively provided. I didn't see the need to explain in detail that information. And I didn't use the old .org method which would be to tell you to search for it yourself and help you no further.
PROVE IT.
Wait, I recall something about someone working at a race shop.
Wow,
This thread went to ****.
Learned a little more about my car though
This is the dumbest sheit I've read in a while. I understand why some people here don't want to help anyone else, just to have it thrown back in their face and called ignorant.
Hey you kids, Get the fock outta here!
http://forums.maxima.org/showthread.php?t=451198
Edit: posted by Deckdout2 under fiance's sn.
theres a 2 stage vtec found on the b18c1 motors, 1 stage engaged with oil pressure and the other engaged with a butterfly(vacuum)this butterfly method is also used on the v6 vtec's as well. some of them at least. most are a single stage vtec using the oil pressure. im not sure how the nissan varible valve deal works cause im new to the max. i came out of a 95 civic hatch running 10psi through a b18c1 stock bottom end motor using the V-afc hack on 440cc injectors. would the V-afc work with the nissan the same way as it would with the VQ, i dont think so. different setups.
Since we have no VTEC to engage...
Originally Posted by SR20DEN
........................ The SAFC-II map is a 12x2 but the VAFC-II map is 12x2x2. If you setup the Hi/Lo VTEC maps not to overlap at all you can have a full 24 rpm points to tune with (24x2). But you would also have to set the crossover (VTEC or VIAS) point to be exactly in the middle of the two 12 point maps (NE points) you set.
litch
123
01-04-2024 07:01 PM
