9012 Bulbs....
Old 12-02-2005, 08:46 AM
RVC
RVC's Avatar
9012 Bulbs....
I am looking for a replacement/aftermarket headlight bulb for the Max. I don't have the HID's but I do want something brighter. Anyone know where I can get aftermarket 9012's? I searched and found nothing. Thanks.
RVC is offline
Old 12-02-2005, 08:48 AM
Majestic_MAx05's Avatar
From what I've read there is no bulb out there to replace our 9012.
Majestic_MAx05 is offline
Old 12-02-2005, 09:08 AM
kapesports's Avatar
this is true.. there are places other, lighting company that makes them but somehow i can find stores that carries them ? there is a company called crandlepower out in Canada that makes them... the best bet is to go 9006 with a little riggin it will fit..
kapesports is offline
Old 12-02-2005, 09:12 AM
my rear view mirrors flap like a f-ing bird
Tek-Niq's Avatar
yea, from what other members have done to install brighter lights is, used the 9006 bulb and cut down one of the tabs on either the bulb or headlight housing to get it to fit inside. the one tab that you cut will not harm the way the bulb is held, it just need to be cut so all the tabs on the 9006 bulb fit inside the hole so then you can twist and lock it in place..
Tek-Niq is offline
Old 12-02-2005, 09:21 AM
RVC
RVC's Avatar
I thought the 9006 was not as bright as the 9012?
RVC is offline
Old 12-02-2005, 10:18 AM
Tek-Niq's Avatar
good question,
I gave you the 9006 bulb idea, but I think that was an HID swap.. I woudn't be sure halogen vs halogen..
Tek-Niq is offline
Old 12-02-2005, 12:16 PM
You Don't Wanna Play Me
TheGame's Avatar
Try these sites I found the while looking for alternatives, but ended up going with an hid kit.
Scroll all the way to the bottom to see the HB-4 bulb
HB4 Lightbulbs
also try here. Thay have ones in a 9006 platform. I used the 9006 buld in hid and it fit with no modification.
Eurolamps.com
They have 3 types xenon charged Blue/White. direct replacement (no ballast required), Yellow SuperBright ION, and Blue/Gold SuperBright ION
If you e-mail them they'll tell you what set-up will work with your model/year car
Chris
TheGame is offline
Old 12-02-2005, 02:47 PM
dopestar129's Avatar
The 9006 is not as bright as the 9012. You can buy aftermarket 9006s that are WHITER, but not brighter. If I were you I'd stick with the 9012s. They are quite bright and they are a somewhat new bulb type that lasts longer than traditional halogens. So far I have only found these bulbs on the internet. I believe I found replacements on Ebay. Or you could let the dealer rip you off
dopestar129 is offline
Old 12-02-2005, 03:12 PM
RVC
RVC's Avatar
Thanks, I think I am going to forget the headlight thing and just stick with my stock 9012's. I don't want to spend the loot on the HID's.
RVC is offline
Old 12-02-2005, 04:00 PM
kapesports's Avatar
then the best thing would be to get a pair of 9006 that has 6000K.. and u all set!!!
Old 12-02-2005, 08:34 PM
CanadianMoFo's Avatar
Try the 9011, high-beam version of the 9012.
CanadianMoFo is offline
charlestek
06-15-2012 02:02 PM
NitrousOxSys
01-14-2009 06:54 AM
y0_nate
08-31-2007 06:40 PM
05MaXiMaMenG
04-22-2005 11:10 PM
Quick Reply: 9012 Bulbs....
