Wheel Spacers
Old 10-12-2007, 08:36 AM
JG1
JG1's Avatar
Wheel Spacers
For a 5mm spacer, do you need to install longer studs for the lug bolts?
I'm thinking no, but just want to be sure.
JG1 is offline
Old 10-12-2007, 08:46 AM
WSH for teh cup
Kyle00's Avatar
I thought it was anything bigger than 5mm then you'd need the longer stud
Kyle00 is offline
Old 10-12-2007, 08:49 AM
Nations 1st 6th Gen Turbo
chernmax's Avatar
I'm guessing yes since my new Eibach 5mm spacer kit came with new studs!!!
chernmax is offline
Old 10-12-2007, 09:25 AM
JG1
JG1's Avatar
damn that means the rotors need to be pulled.
JG1 is offline
Old 10-12-2007, 11:18 AM
Very sound, Mike
soundmike's Avatar
http://forums.maxima.org/showthread.php?t=397133
soundmike is offline
Old 10-12-2007, 11:21 AM
chernmax's Avatar
Originally Posted by soundmike
Excellent info!!!
chernmax is offline
Old 10-12-2007, 11:23 AM
JG1
JG1's Avatar
So the 5mm spacer takes about 2 turns of the lugnut huh?
I guess I need to check how many turns I have now on my wheels, which are aftermarket. Not sure if they'd be the same as a stock wheel.
JG1 is offline
JG1
JG1's Avatar
Excellent info!!!
did you find them cheaper then this?
http://www.drivewire.com/performance...eelspacer.html
JG1 is offline
Old 10-12-2007, 11:29 AM
chernmax's Avatar
Yes, my set of 4 set me back $121 with free shipping. The set prices you're listing is for a set of 2!!!
chernmax is offline
Old 10-12-2007, 11:31 AM
JG1
JG1's Avatar
have a link?..I can't find the kit
JG1 is offline
Old 10-12-2007, 11:38 AM
JoesRedMax's Avatar
You definitley need the longer studs. I have the same spacers as Chern, and when I first did the front brakes I did not replace the studs. Anyway, after a couple of days I noticed a clicking sound when I was driving, come to find out it was loose wheel lugs. The funny thing is when they were put back on they were done with an air gun. So I replaced the studs and now no more clicking sounds or loose lugs.
JoesRedMax is offline
Old 10-12-2007, 11:41 AM
BadBlackMaxSL's Avatar
Does 5 MM even make a visual difference? It seems really thin.
BadBlackMaxSL is offline
Old 10-12-2007, 11:54 AM
JG1
JG1's Avatar
If thats the case I'm not pulling the rotors back off. Forget it.
JG1 is offline
Old 10-12-2007, 12:22 PM
I Donate! Why Don't You?
xoomer.com's Avatar
Ichiba has 5mm spacers with longer studs fro $59.00 per set of 2.
I got these guys and the craftsmanship is out of this world.
They get more expensive as they get thicker. Here is a link. I think they were listed somewhere in the GB section.
http://www.ichibausa.com/maxima90.html
xoomer.com is offline
Old 10-12-2007, 12:24 PM
dot dot dot ...
NmexMAX's Avatar
If you're going to put on spacers, make it worth it. Add 10 or 15mm. What is the reason you're adding them? Is it just for appearance, or are you trying to clear a BBK? Seems as if it's just for appearance since you are deterred by the fact that you have to remove the rotors. Replacing studs isn't that difficult, it would take an hour max using a rinky dink floor jack for 2 wheels. It's not a hard task in the least bit, so I really don't think you should use that as an excuse.
What is the width and offset of your wheels now?
NmexMAX is offline
Old 10-12-2007, 12:32 PM
xoomer.com's Avatar
Totally agree. I added 10mm spacers up front and it just looks great. I am getting new rims just to clear my BBK because my current setup won't clear the calipers even with 10mm. When I do the install I will still leave the spacers on. They are great!
I took my guy about 20 minutes to change it so yeah a home brew solution shouldn't take more then an hour.
Old 10-12-2007, 12:34 PM
dot dot dot ...
NmexMAX's Avatar
And you can drink your favorite brew while you're changing them.
NmexMAX is offline
Old 10-12-2007, 01:21 PM
JG1
JG1's Avatar
Mainly for aesthetics is the reason I'm considering them. I guess if I have to pull the rotors then so be it. ***** of it is I had them off 2 weeks ago.
What do you guys think? Could use spacers or leave them be? Wheels just seem slightly sunken in, but I don't like when they look like they're poking out either
JG1 is offline
Old 10-12-2007, 01:22 PM
dot dot dot ...
NmexMAX's Avatar
I would definitely get them.
NmexMAX is offline
Old 10-12-2007, 01:27 PM
JG1
JG1's Avatar
5's or 10's?
JG1 is offline
Old 10-12-2007, 01:32 PM
chernmax's Avatar
They already look perfect, IMO if you must go, 5mm spacers is all you need and you will give your car an overall 1/2 inch wider stance...
chernmax is offline
Old 10-12-2007, 01:33 PM
"Ok,Whats next?!?!"
Fastmax05's Avatar
hmmm do i need to get these now...
im a 40 mm offset 245/40/20 8.5 rims
Fastmax05 is offline
Old 10-12-2007, 01:38 PM
JG1
JG1's Avatar
So you wouldn't even bother then huh?
I don't know...maybe I'll keep it the way it is.
JG1 is offline
Old 10-12-2007, 01:39 PM
dot dot dot ...
NmexMAX's Avatar
Instead of asking yourself that question, just visualize your wheel 5 or 10mm out from where it is now.
I like my wheels as close to flush as possible.
NmexMAX is offline
JG1
JG1's Avatar
Are your sitting the way mine do or slightly wider?
I believe my Zinik Adrians have a 40mm offset too.
JG1 is offline
Old 10-12-2007, 01:52 PM
xoomer.com's Avatar
I'd say you can do 10mm front and 5mm rear
Old 10-12-2007, 02:59 PM
chernmax's Avatar
No I would go with 5mm spacers all around!!!
chernmax is offline
Old 10-12-2007, 07:30 PM
JG1
JG1's Avatar
link me to the kit you got...I can't find it for that price.
JG1 is offline
Old 10-13-2007, 07:50 AM
KC's FINEST
KCMAXX's Avatar
I had 5mm on all four with my Foose's. It looked fantastic. The downfall was that I cheaped out and bought the cheap universal disks. The eibach kits have the center bored to fit our hub size. 5mm will look great JG1.
KCMAXX is offline
Old 10-13-2007, 08:03 AM
chernmax's Avatar
Here's the link: http://www.autoanything.com/suspensi...?from_search=1
This is the part number/info
Eibach Springs Pro Spacers
5mm spacers (uses OE Hub Ring)
Part#90.5.05.030.4
Good luck...
chernmax is offline
Old 10-13-2007, 08:18 AM
JG1
JG1's Avatar
ordered!
JG1 is offline
Old 10-13-2007, 08:19 AM
Stang-seeking Max Missile
SMOKIN'MAX's Avatar
KC- what was the offset on the Speedsters? W/ the 5 mm spacers, they look perfectly flush. I'm hoping you'll say ET 35. I have ET 35 on 8.5"w. rim and I think another 5 mm will do the trick.
SMOKIN'MAX is offline
Old 10-13-2007, 08:30 AM
chernmax's Avatar
ordered!
It's amazing how some of the most subtle parts make a dramatic difference!!!
chernmax is offline
Old 10-13-2007, 08:40 AM
KC's FINEST
KCMAXX's Avatar
Honestly, I don't know. I just went and looked at one and they it dosent say. Im guessing 35-40.
The only downfall to spacers was the amount of crap (rain, dust) thrown from the front wheels.
KCMAXX is offline
Old 10-13-2007, 10:06 AM
chernmax's Avatar
But with 5mm spacers, it will still be minimal...
chernmax is offline
Old 10-13-2007, 10:32 AM
JG1
JG1's Avatar
KCmaxx, did you end up installing the new studs or you used the existing?
JG1 is offline
Old 10-14-2007, 01:27 AM
!PrjctMax!'s Avatar
You guys think that 5mm in the front and 10mm in the rear would make mine flush?
!PrjctMax! is offline
Old 10-14-2007, 01:42 AM
dot dot dot ...
NmexMAX's Avatar
I would say so
NmexMAX is offline
Old 10-14-2007, 01:46 AM
!PrjctMax!'s Avatar
I would say so
lol another late intoxicated night, ej?
Old 10-14-2007, 02:00 AM
dot dot dot ...
NmexMAX's Avatar
Not yet. I was the DD earlier, but now I'm home, so I made me a stiff one
NmexMAX is offline
Quick Reply: Wheel Spacers
