Ok, here is the procedure for
painting the chrome insert for 6th generation Maxima
headlights.
BEFORE pictures of
headlights.
The first step is to remove the grill. The plastic fasteners are easy to remove. If you have two small flat blade screwdrivers, like I didnt have, you put each one on one side of the center part and pull it up. Then grab it and pull the whole fastener out. Put the grill aside somewhere where you won't step on it.
Now its time to remove the whole front bumper cover. You will need a phillips screwdriver and ur small flat blades. Start on either side of the cover. First you need to have access to some of the fasteners and screws. These are hidden behind the fenderwell plastic covers. Remove the fasteners that hold the fenderwell plastic. Remove enough of them that you can pry it open to get ur arm in the TIGHT space to remove the screws.
Once you get the fenderwell trim open, there are two screws that hold the cover on. They are hard to get at, but try. Unscrew the two screws. Then go underneath and see many fasteners that hold the underside pastic tray to the bumper cover. These were harder for me to remove. But I got them undone. Now do the other side.
