Go Back   Maxima Forums > Maxima Discussions > 6th Generation Maxima (2004-2008)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 09-05-2004, 04:23 PM   #1
Engine turns over, but won't start
Went out yesterday morning to start the car, and it turns over but will not
fire. Plenty of gas. Good battery, lights work, radio etc. Starter turns the
engine but that's it. Any ideas? 6 months old with 6,100 miles.
high888 is offline   Reply With Quote
Old 09-05-2004, 04:59 PM   #2
CanadianMoFo's Avatar
Points: 11,042, Level: 69
Points: 11,042, Level: 69 Points: 11,042, Level: 69 Points: 11,042, Level: 69
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Well a funny thing happened to me once. I blew a small fuse that controls if I recall correctly, the ignition control module.
Under the hood, there's a panel near the washer fluid container. Remove the little fasteners, and beneath is a fuse panel. It can be pulled out to gain access to the fuses and relays at the side. They are the mini type fuses that you can't see through to tell if they've blown or not. You'll likely need a circuit tester, or I bought a little mini-fuse tester specifically for them.
Go through them and likely its could be the 15A one on the ignition control module.
CM.
__________________
Performance Mods: Silver Nismo 19" rims, Injen CAI, Progress Springs & RSB, KYB GR2's, Raceline Endlinks & MMI's & FSTB, NWP Spacers, SS brake lines, xdrilled rotors & ceramic pads
Cosmetic Mods: Painted lower grill, Trendz billet grill, silvered turn signal bulbs, Batmobile sidemarker overlays, 4300k/6000k HID's
CanadianMoFo is offline   Reply With Quote
Old 09-05-2004, 05:56 PM   #3
Heard that happing to a few Murano's, Armada It was something in the ignition switch..
Max'D is offline   Reply With Quote
Old 09-05-2004, 06:26 PM   #4
04SEelite's Avatar
Points: 6,638, Level: 53
Points: 6,638, Level: 53 Points: 6,638, Level: 53 Points: 6,638, Level: 53
Activity: 0%
There is a TSB on this - check with your dealer...should be under warranty.
__________________
04SEelite
04SEelite is offline   Reply With Quote
Old 09-06-2004, 06:17 AM   #5
Send a message via AIM to PETZUK
There is a TSB that covers no or hard starting when the outside temperature is cold. The fuel pump is the problem.
Mine did this and the new pump cured the problem.
However, this occurs under very cold conditions, which I don't think you have in Phoenix..... But, maybe the pump is causing your problem.
PETZUK is offline   Reply With Quote
Old 09-06-2004, 07:24 AM   #6
I am towing it to Pinnacle Nissan Tuesday morning. We shall find out. And yes,
it was about 99 degrees here yesterday, so it was not a cold start.
Old 09-06-2004, 10:52 AM   #7
confident nissan owner
Nismotech1's Avatar
hey i work for a nissan dealer in fl and the only problem i have seen is a bad cam or crank position sensor, if this is the problem a dealer will find it in no time using conult.
__________________
Shift_WHOA!!
maybe its time to get boosted!!!!!!
Nismotech1 is offline   Reply With Quote
Old 02-13-2007, 07:59 AM   #8
DRod's Avatar
Sorry to raise a thread from the dead, but I didn't want to be redundant.
Anyway, I was driving down the highway last night when I tried to pass someone...and my car didn't go any faster. I then tried the manual shift (I have a 5A) and it was stuck in 5th. So, I tried my best to keep the car alive all the way to the dealership. When I got there, we tried starting the car again. No dice.
Ended up it was the cam (crank) position sensor. They replaced both (had no idea there was a "both"). Under warranty, so it's all good.
__________________
14.50 @ 97.98, 2.21 60' - Stock
14.27 @ 97.36, 2.16 60' - Fujita CAI
DRod is offline   Reply With Quote
Old 02-13-2007, 11:06 AM   #9
I Donate! Why Don't You?
xoomer.com's Avatar
Points: 8,284, Level: 61
Points: 8,284, Level: 61 Points: 8,284, Level: 61 Points: 8,284, Level: 61
Activity: 0%
What is it with these cars and cold temperatures. Don't nissan test their vehicles in sub-freezing conditions. For past two weeks (freezing temps on the east coast) everybody is having problems with HUs, starters, etc,etc, etc.
xoomer.com is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
