Go Back   Maxima Forums > Maxima Discussions > 6th Generation Maxima (2004-2008)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-21-2003, 10:37 AM   #1
Tire Rotation on 04 SE
Took my SE to Performance Tire for 1st rotation and balance check at 8000 miles. They are telling me that I should do at 4000 miles not beyond 5000 miles.
They seem to think it is critical on my car, going over that milage limit will casue the tire edges to "feather" and give problems later on. I did buy lifetime rot/bal for tire life for $100. So not in their interest to have me come in so often?
Any comments welcome
Memphoman is offline   Reply With Quote
Old 11-21-2003, 12:10 PM   #2
It's always in their best interests to get you in as often as possible. They can inspect your tires more often and maybe convince you it's time to replace them ... they may find evidence of uneven wear and maybe sell you an alignment or new struts ... they may find a puncture and get a repair charge ... as much as anything else, you just get used to the idea they are the tire place, and when it's time, they hope you'll come to them.
I've heard and read all the arguments for rotation, but to tell you the truth I'm a non-rotator. I just let the fronts wear out, then replace them. Then, when the rears wear out later on, I replace them. That way, I seldom have to buy more than two tires at a time.
Rotating will buy you a little more time by evening out the wear. But it will also introduce more potential problems, by having your wheels mounted and remounted a number of times, by switching the physical location of tires that have "bedded in" to a certain location on the car, by requiring re-balancing, etc., etc. Each of these operations can potentially get done wrong, and/or introduce new problems.
I say if your tires are performing properly on the corner where they are now ... leave 'em alone.
Just my 2 cents worth.
Mike
Mike_TX is offline   Reply With Quote
Old 11-21-2003, 05:28 PM   #3
I also bought tire rotation and balancing before on my camry. The next tiime you go for balancing and rotation, they would tell you that they are busy or leave your car, plus the balancing and rotation is only good on your current tires. Discount tire have specials on balancing and rotation for less than $20.00 every month in my area. If you are a paying customer, they would do it right away.
tko507 is offline   Reply With Quote
Old 11-21-2003, 06:03 PM   #4
Send a message via AIM to Redsand187
Too bad you guy's didn't live in the North West, Montana, or Northern California. We have a tire chain called Les Schwab. They do all that stuff free. It's supposed to be just for people that have bought their tires through them, but they carry most brands, and can order any brand of tire you want. They never check for paper work, because they really don't care.
Redsand187 is offline   Reply With Quote
Old 11-27-2003, 12:38 AM   #5
not paying a tire jockey to touch my wheels
[font=Impact]Yea, I rotated my wheels myself. A great time to clean up and paint the hub surfaces of the rotors...$100;No Way
04maxima is offline   Reply With Quote
Old 11-27-2003, 05:37 AM   #6
I get sick of waiting and waiting and waiting at all those tire places with lifetime rotate/balance......
It's best to rotate/balance the tires AS NEEDED. If you car feels fine and you get the tires balanced it could end up worse than before, esp. if the car sits for a long time before they take the tires off.
A lot of softer, high performance tires can flat-spot easily if they sit. The only way to get an accurate balance is for the tires to be warmed up for at least 10 minutes. Drive the car and immediately put it on a lift.
I think Infiniti dealer producure is to test drive every car before rotate/balance. Not sure if they actually do it..... worth asking for at if you have balance problems. I doubt tire places would care.
greg_atlanta is offline   Reply With Quote
Old 12-01-2003, 12:21 AM   #7
For this post, I will put my comments in these {brackets}.
Quote:
{I believe that this is the case -- it certainly makes sense.}
{This used to be my position -- buy 2 tires rather than 4 -- until I totaled a car when it hydro-planed due to water on the road and not enought tread on the rear tires, even though they were not worn to the "wear bars." I was then advised -- by an auto technical expert -- that vehicles are much more stable and predictable if the tread on the front tires and the tread on the rear tires are as close to the same as possible. Also, that you should replace your tires before they wear down to the "wear bars." For the best performance, you should replace all 4 tires at the same time -- this will ensure that the tread depth and pattern is the same on all four wheels.}
{The "little more time" is true, but consistant, even tire wear front to back is more important for safe vehicle operation. The "potential problems" come from incompetant technicians at the tire store/dealership. If you can't watch the whole operation, I suggest you do the rotations yourself. I have a floor jack and jack stands, and it gives me a good opportunity to inspect each tire carefully for nails, cuts, bulges, etc. When I rotate my tires, I switch the front with the rear tire on the right and then switch the front with the rear tire on the left. That way the tires that have become used to rotating in a certain direction are still rotating in that direction.}
SilverMax_04 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
