KS LEDS
LEDS
1. Brand new pair 1157 60smd led fron turn signal amber(not yellow) and white(6000k)dual circuit + load resistors ( 6 Ohm 50W ),plug and play with no trouble . $43 shipped (US).
2 set available
2.Brand new led changing colors strips ,this will fit perfectly for ur footwell set up or can be in headlight mod :
came with 2 strips 24 5050 smd ,15 3/4 '' long per strip
controller + remote
Wires long enough to connect for both sides work together
T10 adaptor (194 168 158 175 socket) if use for footwell
Can change up to 16 solid color as you wish (red green blue white...etc ) and flash, trobe,fade,smooth motions .Even turn it off completely when power supply is there (when door open ,when used for footwell).This option will be great for headlight mod .
You can draw power pretty much any where you want bc its only turn on when you want it to . $40 shipped
2 set available
3. Brand new pair 13 5050 smd white 6000K for ur doors bulb $13 shipped
4 set available
If you want blue let me know I can swap them out
Let me know if you interested or question huyhale1@yahoo.com
2 set available
controller + remote
2 set available
4 set available
2000 Nissan frontier ext. cab. Have anything for me? Dash LED conversion, all interior lights, headlights, etc.....old friend
Thank you VERY much for my LED gauge cluster and interior LED lights in my SER. It wouldnt have been possible without YOU!
I still get excited when I drive the SER, and its a major plus the wife likes it as well. Awesome work!
thank you , it shipped
Update : load resistors is sold out,if someone still want the 1157 (listed) there are will be no resistors and price for bulbs = $33 shipped (US) . 1 set left
New items = 2 led strips for ur footwell :15smd 5050 led 6500K plug and play (if ur MAX came with light) $14 shipped ,4 available
Back up/reverse = 2 bulbs 912 socket with 68smd 3020 led 6500K $23 shipped (US) 5 available.
Some of model come with 992,7440 socket for reverse here you go = 2W high power with projector lens 6500K(light straight forward and more distance).$20 shipped. Size length 2.115'' Dia .980''
3157 3156 high power 2W with projector lens 6500K .Size length 1.980'' Dia .980'' ,$20 shipped
Thanks for looking
Still would like to get some LEDs for my Frontier. I guess I should just pm you the list of what I need. Also...I cant find what type of bulbs are in the guage cluster. They twist out, and are mounted on little plastic things, similar to the one or twon on the guage cluster of my SER but there are many, many more on the Frontier. Wish I knew what they were called so I could explain them better. Good to see your still around buddy!
Its the brown holder in these pics...
4DRZ buddy , I know exactly what bulb they are , also know they do have them at Vled ,but what they selling is the round head either 5mm -9mm ,the bad things about them is the base not sure will be exact with the factory base + round head will give you more hot spot (uneven light) .Take a look at the pics (Altima 02 -04 cluster ) they used the same bulbs like ur Frontier and I moded them into SMT led ,this will give you even more light + wide view angle (more even light like newer car like ur SE R or MAX)
I used the same/exact base from cluster by took the bulb out and solder led in (I can do this with any incandescent bulb 12V).
Let me know exactly what you need for ur truck (ANY) ,I'll set you up with something for you no need for search my friend
doctorpullit
10-28-2019 10:58 PM
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
