6th Generation Classifieds (2004-2008)See what members are selling or buying for the newest generation Maxima.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
13" two piece rotors, 4 piston caliper, black. Fits 6th & 5th gen, Z & G, altima L31.
1000 OBO! Needs to go!
Although the 6th gens use the same sized oem rotors as the 05+ G/Zs, I don't think this kit is compatible with all the above. IMHO, it fits either just the 6th/5th (probably 4th and 3rd if that's true) or just the G/Z. Not both. FWD and RWD Nissan/Infinitis have traditionally different caliper mounting dimensions making swapping brake caliper inbetween the two impossible (unless you have a bbk bracket specifically made to do so)
Did you actually have this installed on your 6th gen?
Yes I did, and I assure you it fits all of the above. The alignment is the same the only thing that is different is the spindles themselves.
The problem ended up being that the bracket was cocking and I didn't notice. Took a mill or two off and everything fit. No spacers or anything else, just me thinking to hard and not looking at the obvious. It's a bolt on affair with just the brackets and calipers.
I don't get it. How is shaving the bracket going to give you more room? i guess I need pics. But if you alterned the mounting dimensions, then it will no longer fit correctly on a Z or G. Which goes back to my original statement about the mounting differences inbetween the 6th gen and the G/Z.
Essentially, this is a 6th gen / Altima only bbk now right? Still a good deal though
No, it still fits a Z/G. I didn't alter the mounting holes. I'll post a pic later tonight to clarify. Basically the inner edge of the bracket was barely touching the spindle which cocked it when fully tightened.
The gray area in the first pic is the part that was removed. The second pic is a side view so you can see it doesn't effect alignment. The valley is just slightly deeper all the mounting holes are the same. It allows it to clear the slightly higher spindle on a Max/Altima.
hi, how do you think my non-ABS brake master cylinder 05 altima will support these calipers? they have problems pushing the se-r calipers - it is soft and to the floor.
If it means anything, I bought a whole bunch of suspension parts from this guy and they all came in nice and for a decent bargain, Easygoing good guy to deal with.
__________________
Jl Audio 13W6V2 Connected to a JL Audio 500/1 Amp, Directed Remote Start, Valentine One Hardwired + Concealed Display, RTP Cross-Drilled/ Slotted Rotors With Ceramic Pads + SS Brake Lines, 3K Fogs, 35% Tint, 07 Spoiler, G35 18" Wheels, Nismo Intake, Active Tuning Grounding Kit, LED Tails, Optima Red-top, LED domes.
ANYONE LOOKING TO TRADE IN, SELL or PART THERE 07/08 WHITE MAXIMA PLEASE PM ME!
