Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 06-07-2002, 09:31 AM   #1
2002 Maxima SE 0-60 times?
I just bought a new 2002 Maxima SE. Unfortunatley for me my wife can't drive stick shift, so I got the automatic. I can't believe how fast and smooth this car is. My other car is a 330 horsepower Pontiac Firehawk, so I know when a car has power. I was wondering if anyone knows what the 0-60 times are for the Maxima SE with the auto tranny. I know the commercial used to show 0-60 in 6.4 seconds. Thanks in advance.
Frank
fpblue is offline   Reply With Quote
Old 06-07-2002, 11:20 AM   #2
Points: 10,935, Level: 69
Points: 10,935, Level: 69 Points: 10,935, Level: 69 Points: 10,935, Level: 69
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Send a message via AIM to Bulldawg
Re: 2002 Maxima SE 0-60 times?
Quote:
Frank
I got a 6.46 0-60 using a gtech pro. But I have a six speed and I can't drive worth a sh**
__________________
Stillen FSTB, Addco RSB, JIC FLT-A2, Powerslot Rotors, Hawk HPS pads
Bulldawg is offline   Reply With Quote
Old 06-07-2002, 11:31 AM   #3
The 2K2 auto does 0-60 in 6.8-7.0 seconds. That is assuming you drive your auto without manually shifting it like some org members do.
__________________
2001 Maxima SE 5-speed
Sterling Mist / Black leather
AE aero kit / AE door sills
AE splach guards / FSTB / K&N Mobil 1
jkratzer is offline   Reply With Quote
Old 06-07-2002, 11:37 AM   #4
Sanduguero
Points: 9,326, Level: 64
Points: 9,326, Level: 64 Points: 9,326, Level: 64 Points: 9,326, Level: 64
Activity: 0%
Send a message via AIM to Playero Send a message via Yahoo to Playero
is it safe to manually shift a auto 2k2???
__________________
"El Mafioso"
Playero is offline   Reply With Quote
Old 06-07-2002, 11:41 AM   #5
Quote:
...Yes, but don't rag out your engine hitting the rev limiter, you have to drive it like a clutchless stick, and time your shifts so you don't go out of the power band. But there is no question that shifting the gated shifter manually from a stop position will yield better acceleration times... If Motor Trend can get the same curb weight, 15 hp less auto Altima to 60 in 6.6, I am certain that the 02 Max auto can duplicate that, if not improve upon it...
__________________
2k2 SE auto...
H&R Sport Springs w/ Addco RSB & Courtesy FSTB...
Falken Ziex ZE 512s (225/50r17)...
Mobil 1 Syn ATF w/ B&M #264 Tranny Cooler...
PIAA Xtreme White fog bulbs...
all 4 clear corners/Polarg hyper-white bulbs inside/out...
AE Max door sills & 'all 3' aluminum 350Z replica pedals (thanks wild *****!)...
Matthew is offline   Reply With Quote
Old 06-07-2002, 12:39 PM   #6
How do you manually shift an automatic?
I've never done this before. How is it done? Thanks.
Old 06-07-2002, 02:27 PM   #7
Sanduguero
Activity: 0%
Re: How do you manually shift an automatic?
how do i know whats the max on the 1,2,3 gears when is close to RED!
__________________
"El Mafioso"
Old 06-07-2002, 02:36 PM   #8
Points: 13,312, Level: 75
Points: 13,312, Level: 75 Points: 13,312, Level: 75 Points: 13,312, Level: 75
Activity: 11.4%
Activity: 11.4% Activity: 11.4% Activity: 11.4%
You can run lower than a 6.8 I run a 6.61 and some other guys here run similiar times to me in my 02 Auto.
MONTE 01&97 SE is offline   Reply With Quote
Old 06-07-2002, 02:50 PM   #9
...You should really only do this if you have an 02, with the gated shifter, because it has all the gears laid out 1-2-3-D so you can row through them with the 'slushbox' instead of the clutch, but at least it gives you a little more control as to when the car shifts. I think 6.6 0-60 is definitely attainable with a little practice.
__________________
2k2 SE auto...
Old 06-07-2002, 03:43 PM   #10
Re: Re: How do you manually shift an automatic?
Quote:
On manually shifting the 2002 auto, what do you guys think of this:
Because it is very difficult to get from 1st to second, start in 2nd gear, and shift to 3rd and OD. Will this hurt the tranny? It just seems when you manually shift, it really does ni get to the next gear until the trans itself is ready to.
lcj2002se is offline   Reply With Quote
Old 06-07-2002, 03:47 PM   #11
I miss the .org!
Triple8Sol's Avatar
Re: Re: 2002 Maxima SE 0-60 times?
Quote:
Which G-Tech do you have? There's a newer one that came out, with double the features for double the price. I wonder how accurate those things are...
__________________
VORTECH '03 G35c 6MT
Triple8Sol is offline   Reply With Quote
Old 06-07-2002, 04:07 PM   #12
Points: 8,499, Level: 62
Points: 8,499, Level: 62 Points: 8,499, Level: 62 Points: 8,499, Level: 62
Activity: 0%
Re: Re: Re: 2002 Maxima SE 0-60 times?
I was curious on times for all the 2k2 with 6-speeds?!
__________________
6-speed, 2k2 SE
Majestic Blue on Frost interior, Painted front grille w/GrilleTech lower valence
Maxspeed lowering springs, Cattman Performance rear sway bar
Clear corners, Polarg Hyperwhite bulbs, FSTB, Berk intake, Frankencar mid-pipe
Need more mods!
dino1063 is offline   Reply With Quote
Old 06-07-2002, 04:09 PM   #13
Points: 11,516, Level: 70
Points: 11,516, Level: 70 Points: 11,516, Level: 70 Points: 11,516, Level: 70
Activity: 0%
Frank
I just bought my 2K2 Max back in March and got an auto tranny because of the wife also.
As for the 0-60 time, that commercial sounds right on. At the track, I consistently run about 15 flat which roughly equates to about a mid-6 0-60 time.
__________________
F23A4 (Romans 3:23; John 3:16)
2002 Maxima SE 4AT :
2005 Nissan Murano SL AWD
2000 Nissan Quest SE
F23A4 is offline   Reply With Quote
Old 06-07-2002, 05:03 PM   #14
I did 1 run with my G-Tech and got a 14.97 quarter mile... I really don't remember my 0 to 60 time. I think it was in the mid 6's. I think with more runs and cooler weather (I live in deep South Texas..HOT!), I could improve those numbers a little.
__________________
G
ford5litre is offline   Reply With Quote
Old 06-07-2002, 05:08 PM   #15
Quote:
I just did a search on my old thread... my correct quarter mile time was 14.99 and my 0 to 60 was 6.4 in my '02 Auto.
__________________
G
Old 10-21-2002, 09:52 AM   #16
Re: Re: Re: How do you manually shift an automatic?
I agree the shift from 1st to 2nd is physically the most difficult, as you have to kind of work it around. Unfortunately I think manually shifting from 1->2 will net you the biggest gain.
I've found that for whatever reason (even under full throttle) the tranny shortchanges 1st and shifts into 2nd very early. If left alone (like in "D" or "3") the tranny will shift 2 -> 3 much better (closer to redline) than it will 1 -> 2.
Just be sure to give it a few 100 RPMs or you will hit the rev limiter.
__________________
2002 Maxima SE - Sunlit Sand
soopermax02 is offline   Reply With Quote
Old 10-21-2002, 12:42 PM   #17
Send a message via AIM to WILLSE
Re: Re: Re: Re: 2002 Maxima SE 0-60 times?
Quote:
i havent ran my car for awhile but last time i did i set the g-tech up on a perfectly straight road and had everything set up perfect. i did 3 runs 0-60 i consistanly ran between 5.7-5.9 (my clutch probably didnt like it too much). reference note- i ran a 14.3 @ 97 at the track. i wish i had HLSD life would be much more enjoyable.
will
__________________
2k2 6 speed grey luster fully loaded..... Stillen Headers, KYB GR2s, eibach prokit, stillen: RSB, RSTB, FSTB, franken car performance intake, RT high flow cat, HKS rear section, 2.5" custom b-pipe, stillen front x-drilled rotors w/ stillen pads, 17x7 konig imagines, 225/45/17 Kumho Ecsta 711s, AE sill plates, clear side markers, and lots of audio mods. (might have forgotten a mod or two.......)
WILLSE is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
