Neat trick for resetting the ECU
I took this from an article in the June edition of Sport Compact Car:
". . . we reset the ECU by disconnecting the battery. Electrons remaining in the system were purged by stepping on the brakes, leaving the ECU with no memory."
Now if I'm reading this correctly, you don't need to disconnect the battery and leave it disconnected overnight to completely reset the ECU. All you have to do is disconnect the battery and step on the brakes. If that's the case, you should be able to completely reset the ECU in a matter of minutes rather than a matter of hours.
Pretty slick, huh?
Pretty slick, huh?
Originally posted by kloogy
So , does this mean I can put 235/40's on my 17X7's......LOL/////Just kidding !
Re: Neat trick for resetting the ECU
Pretty slick, huh?
Pretty slick, huh?
Re: Re: Neat trick for resetting the ECU
Originally posted by max_speed97
will this work for the 4 generations also???
Re: Re: Re: Re: Neat trick for resetting the ECU
maybe its only for the wrx and not other cars..???
Re: Re: Re: Re: Re: Neat trick for resetting the ECU
I don't think electrons behave differently in a Maxima than they do in a Subaru.
Re: Re: Re: Re: Re: Re: Neat trick for resetting the ECU
Originally posted by Menacer
I read in some post that when you disconnect the battery to reset the ECU, you are not actually resetting the ecu. I have heard that it is best to reset the ecu when you go to the dealer for service if you caused a malfunction on the car. For example, I am racing and suddenly something is wrong with it. If I go to the dealer hoping to get it fix under warranty for something that was obviously my fault then they have a way of knowinf without you telling them. i guess when they hook up the car to a computer it tells them exactly when the when the error code came up. For example if I get a code for a certain transmission malfuction, the technician can see at what speed, what gear, what rpm, how open the throttle was at the time of the malfuction. basically it tells them whether you were abusing the car. So by resetting the ecu all these things are not recorded for the tehnician to know whether the car was being pushed to hard. Does this make sense? What do you guys think?
A variety of reasons exist for resetting the ECU, not all of which involve a tripped SES light. The ECU should be reset any time you install a major performance modification such as an aftermarket intake or a Y-pipe. Resetting the ECU places it in learning mode and reduces the risk that the modification will generate a SES light when power is restored.
FWIW, I'm convinced that the information presented in the Sport Compact Car article is correct. It simply makes sense technically.
Anyone who resets their ECU by disconnecting their battery and letting their vehicle sit for hours on end is wasting their time. Just disconnect your battery, step on your brakes, and voila . . . mission accomplished.
[quote]Anyone who resets their ECU by disconnecting their battery and letting their vehicle sit for hours on end is wasting their time. Just disconnect your battery, step on your brakes, and voila . . . mission accomplished.[quote]
All this achieves is draining out any charge that is left. You can also:
Disconnect battery and
1)Leave your lights on.
2)Leave your radio on.
etc
Brakes have little to do with it, other than lighting up the rear lights.
etc
[QUOTE]Originally posted by 2002 Maxima SE
etc
Agreed, 2002 Maxima SE. I think it's just a matter of which method is the quickest. I assume that Sport Compact Car's Subaru WRX had lights and a radio. Yet they chose to drain the electrons by stepping on the brakes. That's good enough for me.
But those in a REAL hurry could always leave their lights on, leave their radio on AND step on the brakes.
etc
I am almost possitive it wont work on the 2k2. Every other car I have had I can reset the ECU is some fashion (either by switch, wire, ground, or pulling the battery) but I have tried everything on my 2k2 and the only way it happened was by driving it until I hit @ 50 restarts. Maybe when I get bored I will trip my ECU and try this, but I highl;y doubt it will work. They did something new with these ECUs.
The ECU probably has a small battery attached to it that is constantly charged. That way, in case the main battery is disconnected for service, the ECU will not lose any memory. This would be similar to the extra battery on Palm's to prevent memory loss when the AAA batteries die and need replacing.
Funny thing, my SES light came on for the first time ever last week. So, when I got home that night, I disconnected the battery - positive cable - and left it overnight. Left the hood down but not latched to fix in the am.
The next morning, hopped into the car and started it up - without reconnecting the battery! Then noticed the hood was up and thought - gee I need to reconnect the battery - and turned the car off. Only then did I realize that the car started with the battery disconnected.
SES light went off and stayed off, though.
but with the resetting of the battery thing, i've also heard about disconnectiong the battery, and then proceeding to turn your lights on, and that should drain the capacitors and all the power from the system.
First, if there's enough juice left in the electrical system with the battery disconnected to start the engine, is there enough juice to prevent the ECU from resetting itself?
Second, how long would you have to step on the brakes (or leave the lights on or leave the radio on or all three) with the battery disconnected before enough juice drains from the electrical system to prevent the engine from starting?
It might be interesting to run some experiments if someone has the time and the desire to do so.
Fascinating. That brings up a couple of questions.
Pretty slick, huh?
Pretty slick, huh?
cool!
and thanks!
this could be very useful.
Originally posted by Maksim2000
I've tried the brake trick after my CEL came on and it didn't work... light stayed on after I've re-connected the battery. Now leaving it disconnected for about an hour did reset the light...
BTW, when you tried the brake trick, did you do it long enough for the brake lights to go out completely? Just curious.
Originally posted by Y2KevSE
Oh well, it sounded like a good idea at the time.
Thanks, Kev.
Re: Re: Re: Re: Re: Re: Re: Neat trick for resetting the ECU
Originally posted by mzmtg
Since when does WOT and high speed constitute abuse?
Pretty slick, huh?
Pretty slick, huh?
Originally posted by lcj2002se
So what is a ECU and what does it do????
Allow me to introduce you to some of the features of the 5th Gen Forum. First, I'd recommend that you take a look through the Frequently Asked Questions (FAQ) thread. Although you may not understand everything you read, you'll run into it if you stick around here long enough.
We use a lot of abbreviations around here. There's an excellent thread on Page 4 of the FAQs that lists the most common ones, including ECU.
FYI, the ECU is the brain of your Maxima.
Originally posted by Viciousss1
If i did disconnect the battery and hooked it up the next day.
how would i know if the ECU was reset?
SES always comes back on (after Budget Y-Pipe)
I have tried leaving the battery disconnected over night a couple of times and the light still keeps coming back on. Do any one you have any ideas. The pipe sounds great but is it causing any damage? Sensors where put back in place. However, I do hear a whistling noise at high rpm. May have exhaust leak. Would this trigger the light and if the light stays on could it cause damagae to anything in the long run?
