clogged main cat
Old 04-22-2024, 04:23 PM
5thgendriver's Avatar
clogged main cat
no codes..replaced MAF, TPS, tranny solenoids, temp sensor, fuel pump.
pulled the front cat and this is what I found. got one coming so I'll update the thread once it arrives and I install. didn't think to gut it before I ordered it. the rest of the exhaust have all ready been replaced with cattman.
symptoms were the car wouldn't rev past 2500 rpm in park.
5thgendriver is offline
Old 04-24-2024, 12:36 PM
pethelman's Avatar
That's an impressive picture! Sounds like you've really been putting some work into this car... hopefully it's not a major oil burner so that your new converter can last for a while. Crazy that you weren't getting any "below efficiency" O2 codes.
pethelman is offline
Old 04-24-2024, 02:38 PM
no codes and it burns no oil. the problem was it would not accelerate past 2500 in park.
Old 04-24-2024, 04:37 PM
uptownsamcv's Avatar
I heard it's usually a good idea to change out the spark plugs after changing out a bad cat.
uptownsamcv is offline
Old 04-24-2024, 08:09 PM
Reality sucks's Avatar
This is normal, and you are spot on. The cat typically is dislodged and will pull out of its casing. A simple test for this to remove the upstream 02's. The hotter the engine gets the worse it runs in most cases with this and any exhaust that does make it out the back, is piping hott. A full clog of the cats on a 3.5 also makes the engine sound as if its out of time. Craziest sound Ive honestly ever heard. I do not recommend gutting cats, Imo the 3.5 just stinks catless. Keep us Updated.
Reality sucks is offline
gsxr-rider137
11-30-2012 02:00 PM
FreshRichie
34
06-25-2012 08:14 AM
GRNMAXDMON
09-18-2007 02:44 PM
xxrealmsxx
09-30-2005 07:30 PM
ejj
10-15-2000 03:21 PM
Quick Reply: clogged main cat
