So need some heater core bypass knowledge and help.
Old 04-11-2024, 08:21 PM
2000MAXBOY's Avatar
My car began to overheat as I was parked after a short trip, I was idling for less than 4 minutes and it started to overheat, I began driving as it was happening, saw the meter keep creeping up and immediately swung into a parking spot snd turned off the engine. I guess it was too late as she was smoking from hood passenger side, I discovered the two heater core hoses into the firewall broke off and all my coolant gone upon the ground...
Can I just cap those two hoses off or just buy the bypass kit I see in the automotive stores? As you probably know when driving all my water leaks out of those two hoses so I really cannot drive it until I resolve that issue. (I live in Florida, my heat never worked since I bought the car seven years ago, heat does not matter to me but air conditioning sure does.) If I just bypass it or cap them off, will my air conditioner still work perfectly? I have had the air conditioner off since this happened hoping no water would leak if I just did not use it but as we all know now that is not to be. Please help.
2000MAXBOY is offline
Old 04-12-2024, 02:44 AM
uptownsamcv's Avatar
don't just cap the outlets. the way the heater works is constant flow with a blend door under the dash. you can use a brass elbow and some hose from the auto parts store, I forget what size though.
uptownsamcv is offline
Old 04-12-2024, 02:48 PM
2000MAXBOY's Avatar
What about the universal heater core bypass kits? I do not care about using the heat at all at this time. For a long time. I never did in seven years.
Old 04-12-2024, 04:10 PM
chrome91's Avatar
As said you cannot just plug the hoses, you would need to get a brass pipe from a hardware store and some hose clamps and loop the 2 heater core lines together in a loop to bypass the heatercore
chrome91 is offline
Old 04-12-2024, 05:23 PM
2000MAXBOY's Avatar
Yes, I am beyond capping and plugging the two hoses that once went into the firewall and heater core. I am all about heater core bypassing now which I have done with the universal heater bypass kit and testing her out now.
Old 04-12-2024, 07:53 PM
2 hoses and an elbow is as universal as it gets lol. eventually I got a 3/4" silicone U off ebay for a cleaner look.
Old 04-12-2024, 09:25 PM
2000MAXBOY's Avatar
This is the one I got today and managed to get on good. I do not need to use my heat.
Old 04-13-2024, 07:06 AM
I don't have heat either. the plastic heater core extensions broke on me....
Old 04-13-2024, 05:44 PM
2000MAXBOY's Avatar
How long have you been enduring that issue? Did you lose all your coolant? Or...?
Old 04-14-2024, 05:16 AM
it happened while I was pulling out my old engine last march. I live in Florida so I can get away with not having heat.
Old 04-14-2024, 10:59 AM
2000MAXBOY's Avatar
That firewall result is exactly like mine except I have no spacious room because my engine bay is full. I had to work with everything intact. I got it connected. I should supply my final result picture soon. No heat is never necessary.
Old 04-15-2024, 04:22 AM
during the few cold days we have out here I bring a thermos and rags to work so when I leave I can have hot water to wipe down my windows
rmdl51
01-16-2013 06:50 PM
LILMAN
12-17-2010 01:10 PM
CnR's 90 max
01-07-2010 09:03 PM
maximaboi
22
12-30-2004 07:50 PM
Izzrock
10-31-2003 05:35 AM
Quick Reply: So need some heater core bypass knowledge and help.
