Low coolant due to leaking water pump o-ring
Hi, is this going to cause engine damage by driving with slightly low coolant level in the radiator? With the water pump o-ring leaking coolant, the leak stops when the coolant level in the radiator gets maybe about 1/2 inch below the neck. I just drive around like that so it will stop leaking until I can fix it in the spring.
I guess there is air in the system, particularly around the water pump after the engine is turned off.. So far the engine has never overheated.
One more thing I'd like to add is there is still heat in the car from the heater core so coolant is moving. However, as I said, the water pump o-ring has stopped leaking due to I guess enough air in the system to form a nice air pocket in the water pump so it will stop leaking coolant. It seems ideal to leave it that way until the weather warms up and I can replace the orings.
excellent. also for future people my oring was also leaking.
there is a weep hole on the side that tells you it's leaking, by leaking.
if it's leaking there its probably leaking into the engine even though you don't see coolant mixing-in with your meat eyes.
i tested the oil sent it to blackstone and yes there was coolant in the oil.
Because it always drips down behind the ac compressor. There are internal channels to send the coolant there is my understanding. That was what I read and observed and verified when I changed the o-rings. There are two orings, one for coolant and the other for oil. When I removed the old orings, the coolant o-ring just disintegrated while I was trying to slip it off, the rubber was so brittle.
Heres a link to my personal experience with the leaky water pump...
https://maxima.org/forums/5th-genera...g-oil-pan.html
Before I began this repair, I performed a few searches and found other maxima owners stripped out the water pump bolts... idk how they gained the clearance to tap a new hole but that would be disheartening to strip out one of the mounting bolt holes...
tzilla
12-27-2010 08:59 PM
