P0505 error code
P0505 error code
Hi all, My 2001 Maxima SE just threw the P0505 code. I pulled out and checked the ECU / ECM and all the chips look pristine. So can I safely presume that I just need to replace the IACV? I swapped out the 15 amp ENG CONT 1 fuse with a 7.5 amp fuse. I am going to disconnect the electronic engine mounts as well. I just want to make sure that I won't fry the new IACV as long as the ECU is not burnt. I have done hours of searching, my head is going to explode. Thoughts and suggestions are greatly appreciated. Thanks.
John
John
Question, Do I need to do any type of re-learn after I change the IACV? There was nothing wrong with the ECU, just swapped out the IACV. My throttle body butterfly valve looked awesome. Just a teeny, tiny bit of carbon
Help!!!! I changed the OG IACV that with a new one that I bought from Rockauto and cleared the CEL. Drove around yesterday, Idle was great throttle response was great. Started the car just now, and the CEL is back on with the same P0505 code!!! Freaking out, I don't want to fry the ECU. What could be the issue?
iceberg8389
22
07-11-2016 05:46 PM
fuctkeen
07-25-2010 03:30 PM
