Identify this sensor
Old 04-15-2020, 08:24 PM
2KMaximaGLE's Avatar
Hello this is 2000 Maxima GLE, can anyone tell me the name of the sensor pictured(green clip)? Also could it have anything to do with my car being stuck in limp mode? Thanks for your time
2KMaximaGLE is offline
Old 04-15-2020, 08:56 PM
slvr2KSE5's Avatar
Air intake temp.
As for limp mode start by scanning for fault codes.
slvr2KSE5 is offline
Old 04-15-2020, 10:46 PM
Air intake temp.
thank you, I have scanned for codes, reader throwing nothing. I've also replaced the MAF sensor and throttle position sensor. I'm gonna try new spark plugs next, I'm not sure what else to do,
Old 06-04-2020, 06:31 PM
TheVQ35's Avatar
did you try anything else? did it fix?
TheVQ35 is offline
Old 06-05-2020, 04:40 AM
guapoman2000's Avatar
I seriously doubt that the sensor you have pointed out is causing your Maxima in Limp Mode.
Limp mode is a Fail Safe feature from the ECM when "a" special sensor is not communicating correctly to the ECM......
Instead of filling up this thread, how about looking at Post #9 at:
https://maxima.org/forums/5th-genera...limp-mode.html
Best of Luck.
guapoman2000 is offline
Old 06-06-2020, 09:43 PM
The_Fixer's Avatar
Look for a post from tunermax2000 you have a 5th gen and the post from Akshun above is for a 5.5 totally different. Time to replace your iacv,TB and get a new ecu .
The_Fixer is offline
Old 06-07-2020, 10:03 AM
cdoublejj's Avatar
i had my ECU repaired some years ago for the high idle issue caused by a bad iac, also replaced the throttle position sensor too have to do all 3 or it will fry again
cdoublejj is offline
alshamsi
02-12-2020 04:54 AM
knock
02-06-2015 11:05 AM
boondoxmax
03-20-2014 07:00 PM
sterlingmaxima
06-17-2005 09:07 PM
Quick Reply: Identify this sensor
