Best Valve Cover?
Old 02-26-2020, 06:49 AM
ukmastermind's Avatar
Best Valve Cover?
What's the best fit and quality Valve Cover outside of OEM?
ITM
APEX
Beck/Arnley
ukmastermind is offline
Old 02-26-2020, 07:43 AM
Bad *** Newb
Child_uv_KoRn's Avatar
No need to ever use new VCs unless they crack. In that case get a used one (6th gen preferably). If you need tube seals, then use a hole saw and open the ***** up.
I just put RTV on the tubes.
Child_uv_KoRn is offline
Old 02-26-2020, 06:39 PM
uptownsamcv's Avatar
I got some on Ebay but didn't use the included gasket or PCV valve. first set leaked prematurely and seller sent me replacement. the gasket that came with them got hard and brittle quick and leaked within a month...
uptownsamcv is offline
Old 02-28-2020, 08:24 AM
What brand gasket did you end up using? Fel pro?
Old 02-28-2020, 08:25 AM
Looks like the gasket let go AND I have a 2 hairline cracks near the bottom.
Of course, it's the valve cover on the back of the engine, under the intake
Old 03-06-2020, 02:09 PM
Update:
Beck/Arnley Brand is over double the price of other after market valve covers, but it's Nissan OEM. Even the gasket is Nissan, Made in Japan.
Old 03-21-2020, 02:01 PM
Yes, I went with the Fel-Pro gaskets and a PCV valve from the parts store just in case..
Old 04-18-2020, 07:24 PM
DAP
DAP's Avatar
Update:
I ordered the Beck/Arnley last week. It was shipped from Tennessee where the Nissan factory is. I was looking at the cheaper valve covers but from the few reviews I read they are just Chinese junk.
DAP is offline
Old 04-19-2020, 08:07 AM
I'm nutty for Nissans
JSutter's Avatar
Have you successfully replaced the tube seals on the plastic covers?
JSutter is offline
Old 04-21-2020, 12:07 AM
CMax03's Avatar
ITM's work and don't require all that trouble you're headed into Sir! $46 ea...2nd time I'm changing mine in 17 yrs...Seal aren't replaceable they're assembled into the valve cover plastic welded as one unit.
CMax03 is offline
egali045
23
01-24-2015 10:26 PM
ATmax99gle
08-20-2005 10:25 PM
BBaker025
05-16-2002 07:20 PM
maximaR
04-29-2001 08:21 PM
Quick Reply: Best Valve Cover?
