DS Wiper Arm Clicking
Old 01-24-2019, 04:56 AM
Prophecy99's Avatar
About 1 week ago, my driver side wiper arm has started this clicking. The wiper blade it self inst in bad shape (replaced with in 12 months) and it performs as it should, i just have this clicking that occurs at the very start of the wiper arm motion and the peak or end of the wiper arm motion and so on. so if i turned on the wipers, it clicks, sweeps as it should, clicks at the top, and then return. In other words clicks on intial movement , and clicks at the peak.
What gives?
Prophecy99 is offline
Old 01-24-2019, 09:56 AM
DennisMik's Avatar
The arm from the motor to the wiper pivot may have worn bearings. You would have to pull the cowling off to check this. Or maybe try turning off the ignition switch with the wiper blade in mid wipe and see if you can wiggle it and detect any play.
DennisMik is offline
Old 01-24-2019, 10:29 AM
Prophecy99's Avatar
greatly appreciated man, a lot ! will post results. and if worn bearings is the case, whats next? do I need new new linkage or just a wiper arm bearing?
Old 01-25-2019, 06:07 AM
Prophecy99's Avatar
alight great news ! the PS blade itself had slid out of position and wasn't locked in they way it should, so when the arms started to move or stop it caused the arm to click because it didnt have the proper contact, once i fixed the blade insert, everything was smooth as butter.
Thanks!
Old 01-25-2019, 05:43 PM
DennisMik's Avatar
It is a good day when a problem gets solved at no cost. If only it would happen to me.
ffcbairn
03-26-2011 11:01 AM
okay
02-09-2007 07:23 AM
Mike S.
11-18-2005 07:06 PM
dsgi
07-30-2004 03:43 PM
cardana24
18
03-19-2004 07:57 AM
Quick Reply: DS Wiper Arm Clicking
