Wheel, suspension upgrades
Old 08-24-2018, 08:37 AM
JDM4LIFEE's Avatar
New to this, so don't roast me too bad, but I'm seeking advice on my 2000 Nissan Maxima GLE.
I recently found and installed a nice set of 18x8 350z wheels. 245-40-R18's all around. It looks great, but I want to lower it. I'm thinking about the Eibach Pro-Kit Spring set paired with some Koni or Bilstein shocks. Am I headed in the right direction?? Any input would be great! Thanks!
JDM4LIFEE is offline
Old 08-24-2018, 08:53 AM
cdoublejj's Avatar
yeah you're headed in the right direction, lots of threads here with opinions.
cdoublejj is offline
Old 08-24-2018, 10:27 AM
krest265's Avatar
for the price you could probably source some teins and have height adjustability
krest265 is offline
Old 08-24-2018, 12:28 PM
JDM4LIFEE's Avatar
Thanks!!! I appreciate the help.
Old 08-25-2018, 09:56 AM
Theslaking's Avatar
Teins are the way to go for under $700.
Theslaking is offline
Old 08-27-2018, 08:01 PM
CMax03's Avatar
Koni's front struts require a little fab modification, so I would purchase some junkyard front struts to build so you won't be down so long! Invest is chop saw and enjoy those Koni's!
CMax03 is offline
Old 08-27-2018, 08:27 PM
CMax03's Avatar
Here's my 5.5th Gen with Koni Yellows, Progress Technology Sport Springs and 18" x 8" TSW wheels
More Sinister with Gun Metal Grey...
CMax03 is offline
Old 08-28-2018, 01:00 PM
JDM4LIFEE's Avatar
Clean! I love it! Thanks man!
Old 08-28-2018, 08:41 PM
Derrick2k2SE's Avatar
K-Sport Kontrol coilovers give separate height and spring tension adjustments for around $800.00 and are made in Japan. I really like the way they feel. The car corners flat and they're way smoother than my old Eibach lowering kit.
I wound never do a spring/strut combo again. Good coilovers give a way better ride, far better performance at whatever height you want.
Derrick2k2SE is offline
Old 08-29-2018, 12:45 AM
Maxx6spd's Avatar
I have brand new still in box set of tein coilovers for sale $500 dm if interested
Maxx6spd is offline
Old 08-29-2018, 10:44 PM
CMax03's Avatar
Yep...Until it breaks, blows, or starts leaking...My Koni's will be here in 3 days if it isn't under warranty...How easy is it to get your K-sport up and running if there's a problem?
CMax03 is offline
Old 08-30-2018, 07:42 AM
I don't see why they'd be different from any others. They have a warranty. They can be sent back for service or replacement just like any other strut system. The strut can be taken apart and rebuilt which isn't the case with a lot of other struts. Even if they're discontinued, they're will be seal kits for them. After the warranty you pay for it just like any other brand or do it yourself.
Any strut can break, blow or leak. I don't know of any problems with getting parts from K-Sport. I got the kit very quickly when I ordered it.
They have a good reputation so I don't feel like I'm taking any sort of extra risk using them over any others. I don't think they're at risk if failing any more than other brands. The fact that they're made in Japan tells me just the opposite. They look and feel like high quality.
After having coilovers I'll never do another basic spring/strut lowering kit.
Old 08-30-2018, 10:13 AM
Genes1s's Avatar
My experience with Coilovers (on E36 M3), only on good quality Coilovers though that the performance and warranty/service are decent. The more moving parts they have the more chance to fail IMO if it is not high quality. I found that for street/daily use, a good set of struts/shocks would be cheaper/same price as the cheap coilovers ones and they provide better value (performance, quality, and price). You kinda set and forget and it'll perform well.
I'm tempted to do coils on my Max but wondering if it'll make the car any better. My car has KYB + H Tech only but it is heavily braces. The ride is complaint, slightly stiffer than stock but not harsh. It still takes pot holes good and it corners very well. I do like slight body roll just to give me a little warning on the limit. I can adjust the over/under steer by adjusting the rear sway bar. Right now, it's setup to have slight over steer.
Genes1s is offline
Old 08-30-2018, 05:48 PM
CMax03's Avatar
I think the Coilovers are cool but, 7 out 10 people have no clue how to setup nor adjust coilover assemblies properly, nor have the corner weighing scales to properly set up a well balance streetcar!!! All the coilovers setups I rode in rode like crap with a bunch of rattling, and teeth jarring vibrations that wern't anywhere close to the ride compliance of either 3 of my Maxima(s)...5.5th Gen (Progress/Koni), 4th Gen (S-Teins/AGX), 3rd Gen(ST/KYB)...The pillow block bearing setup isn't for the street....Progress' Cattman upper strut mount was an awesome design more like the traditional McPherson strut upper strut mount and was quiet trouble free and durable....So if the coilover owner can't set it up for street use he/she more than likely has no business rebuilding it either....and how much people have a shock dyno to set up the shock properly using pressure per inch of movement? Nobody I know...So their cool and dandy to turn like your on rails...But most coilovers are beyond the scope and detail of most auto hobbyist...
CMax03 is offline
Old 08-30-2018, 06:15 PM
The price of good coilovers has come down a lot over the years. The cost of the K-sport is close to a good spring/strut setup.
If you're happy with the setup you have then stick with it. I wouldn't compare cheap coilovers to good spring/strut setups though.
I prefer flat cornering with a ride height that isn't slammed at all. It doesn't look "lowered" unless someone knows how it should look. If you slam a set of coilovers they'll drive like crap.
Old 08-30-2018, 06:59 PM
I think the Coilovers are cool but, 7 out 10 people have no clue how to setup nor adjust coilover assemblies properly, nor have the corner weighing scales to properly set up a well balance streetcar!!! All the coilovers setups I rode in rode like crap with a bunch of rattling, and teeth jarring vibrations that are anywhere close to the ride compliance of either 3 of my Maxima(s)...5.5th Gen (Progress/Koni), 4th Gen (S-Teins/AGX), 3rd Gen(ST/KYB)...The pillow block bearing setup isn't for the street....Progress' Cattman upper strut mount was an awesome design more like the traditional McPherson strut upper strut mount and was quiet trouble free and durable....So if the coilover owner can't set it up for street use he/she more than likely has no business rebuilding it either....and how much people have a shock dyno to set up the shock properly using pressure per inch of movement? Nobody I know...So their cool and dandy to turn like your on rails...But most coilovers are beyond the scope and detail of most auto hobbyist...
Then 7 out of 10 people can take it to a shop and have them installed, aligned and set up. That's got nothing to do with it. The K-Sports are actually easier to install since they come as an assembly. No compressing springs, fighting the upper bolt etc.... 3 nuts up top, two bolts down low and they're in. If someone can't handle that then they really have no business playing with compressed springs.
I don't know what you've ridden in but I've been in a lot of cars with QUALITY coilovers that ride really well. My K-sports are better in every way than the Eibach/Tokico that I had before.
I do think coilovers get a bad rap because a lot of people don't set them up right or use them to slam the car so it does ride like crap. People think that the stiffest setting at the lowest possible height is the best thing to do. People also buy the cheapest ones they can find off eBay just so they can slam the car. If that makes them happy it's fine. It's just not a good representation of how a good set can improve a car. I have mine setup to corner flat, take bumps reasonably well and have a realistic height.
I don't care what anyone chooses to put under their car and I'm not going to criticize anyones choice. I'm just sharing my experiences with modern good quality coilovers that are properly setup. People can make their own decision.
It comes down to this. If you want the option of setting the car up exactly how you want, get coilovers. If you don't want to think about it, get a lowering kit. Neither one is wrong. It's just a matter of what you want out of it.
Old 08-31-2018, 02:06 AM
CMax03's Avatar
You got some good points there...I've seen some crappy *** JIC setups too...They have now clue what they're doing!!! I listed my Lowered Springs/Strut Combo in Reply # 7 and 14...I'll set up my Shelby Charger on some coilovers but I love my 5.5th Gen and 3rd Gen's drop cause it's subtle, smooth, can handle the rough roads, and still provide a decent ride, and can enter/exit driveway like a normal vehicle.. they're both awesome Highway cruisers... My wife and daughter usually sleep the whole damn way while I handle the driving...Now my 4th Gen it's dropped 2.2" with S-Teins and AGX struts...Nice ride a little rough on sharp bumps, but cool looking when cruizin....This car was a free car and came with this drop...But i understand and yes alot of folks set their coilovers up wrong!
CMax03 is offline
Old 08-31-2018, 10:18 AM
Prophecy99's Avatar
great points here ! i am in agreeance that for set it and forget it springs struts is the way to go. you guys forgot to mention North East Daily driving in the winter, i have heard of many coil overs(even quality ones) having a really tough time up here and lasting as little as 3 years when put through driving in the winters.
my front tokico illuminas lasted 6-7 years daily driving in the NE
Prophecy99 is offline
Old 08-31-2018, 12:04 PM
NotYou's Avatar
Regarding our winters and coilovers, I used to have a link to a place that sells protective covers for coilovers. It was like a big sleeve with a draw string. Claims to keep the salt and junk out of your setup. Just a thought. Ill post it if I can find them again.
NotYou is offline
Old 09-01-2018, 01:25 PM
Prophecy99's Avatar
i kinda remember such a thing! good point
Old 09-01-2018, 03:26 PM
We don't have rust where I live so that doesn't even enter my mind.
My tokico illuminas were over 10 years old and still looked new when I took them out.
My coilovers are all anodized aluminum so I'd think they would stand up to rust as well as a set of steel struts.
Old 09-04-2018, 06:33 AM
Prophecy99's Avatar
i have heard more or less the hydraulics in the C/O dampers didnt hold up well in the North East , could be extremes and rare cases , but when i was searching on what mattered to me way back then, the perception of C/O's not handling a daily driver in the north east winters, kept me away from them. also i would say C/O's have came a long way from then, so it could def be an older way of thinking at this point (this was before super stanced out rides became more trendy). seems like C/O's are all over now a days and some makes have endless brands and possibilities. sometimes I really wish I got to try them out, TEINS SS are super nice in my opinion because they use the stock shock mounts and no rough pillowball mounts. you almost get best of both worlds, C/O settings with a comfy shock mount.
i honestly just remember seeing a lot of local guys needing early replacements even on the highly rated TIENS, and I wanted to set it and forget it. all on priorities i guess.
Old 09-04-2018, 11:19 PM
CMax03's Avatar
Hey it's as suggestive as an exhaust system's note! If you're a C/O fan, Just do it!!! I guarantee they won't outlast an Aftermarket performance strut assembly on a daily driver!!! While driving the normal everyday roads!
CMax03 is offline
Old 09-05-2018, 06:42 AM
Prophecy99's Avatar
roger that! , PA roads are almost offroading too.
Old 09-05-2018, 11:26 AM
MadMax07SL's Avatar
2000 Maxima Bluebook value is around $2000 retail price with under 200,000 miles. You move that to 220k, add a "rough" value, and the tradin value drops from $700 to $57. When the tradin value of your ride doubles depending on if the gas tank is full or empty, It's time to drive that sucker into the ground. Make no frivolous modifications...save your money for it's replacement.
MadMax07SL is offline
Old 09-06-2018, 05:06 AM
Prophecy99's Avatar
im sure the OP knows this, to each their own.
what mileage do you have? whats your plan?
some people like to enjoy their ride rather than saving theoretical pennies that would end up being spent on the next car.
cars always depreciate new or old
Old 09-06-2018, 08:16 AM
MadMax07SL's Avatar
You're 100% right, he's entitled to do whatever he wants to do with his ride. But as a voice of experience, I wanted to make sure he listened to reason as well as technical options above. Often times when I was younger I poured money into a worthless car just because I could. I wish sometimes that voice of reason came to my aid back then, because the younger me could have used the advice.
Old 09-06-2018, 11:15 AM
TSelanne's Avatar
Good discussion here. Only thing I would add is look into KYB excelG struts, they are very good if you decide to go w a spring/strut combo.
TSelanne is offline
Old 09-06-2018, 03:26 PM
CMax03's Avatar
That's funny but true! But sentimental value isn't measurable...I Love My Maxima(s)
CMax03 is offline
Old 09-06-2018, 08:38 PM
Genes1s's Avatar
I would agree with you for modification, u know, fancy wheels, new custom exhaust, turbo charger, headlight retrofit...wait did I say headlight retrofit..nah...headlight retrofit is needed for safety reason only....
Genes1s is offline
Old 09-09-2018, 07:36 PM
CMax03's Avatar
Headlight, suspension, brakes I would say fell under safety as well! But it's how far some go on their safety ventures that defines for safety or overkill!
Yeah especially they show up with 10000K headlights (Unless Lumens)!
CMax03 is offline
drzcrazychulo4u
05-07-2008 03:33 PM
clive
05-04-2006 06:13 AM
MAXIN
04-08-2003 08:29 AM
petmj
10-26-2002 12:19 PM
Quick Reply: Wheel, suspension upgrades
