Power steering belt tensioner
anyone know how to replace it?? I thought I could reach and unscrew the top bolt but I was wrong. Must be a nut on the other side and I知 not sure the easiest way to access it.
i went to change the belt since I知 squeels but the tensioner screw is broken. Already have the new part.
thanks in advance
thanks in advance
I must be slow. I see write ups for the tensioner up too in the engine bay but that is for the alternator belt. I can稚 see where I have access to the power steering belt.
guess I値l keep searching
Here's the video I used to change mine,
. Changing the power steering belt requires you to remove the other serpentine belt as well so it's best to do both at once. I don't recommend doing it yourself unless you have all of the tools needed because these bolts are difficult to access. If your bolts are broken as you say, you're in a tough spot and I would look at getting some repair estimates from some local pro's in dealing with that. Because if you remove the belts and are unable to reattach them, your Max will be inoperable and you'll be looking at an expensive tow bill.
Texakinz
04-22-2015 02:36 PM
sqaeng
02-24-2014 10:34 PM
88FordFestiva
10-22-2009 05:44 PM
