Resonator choice
Old 11-28-2016, 09:19 PM
VQ35maxima=Beast's Avatar
Resonator choice
I know there are a ton of threads over this but I want some personal opinions, and recommendations. I'm looking for a resonator to eliminate some of the raspiness. I have a 2000 with y-pipe, stock cat, and a full custom 2.5 inch cat back. I loved the sound of the full straight pipe before I did the y-pipe, but now that I have the y-pipe it's very raspy up high. Any recommendations would be great, Thanks!
I've been looking at thrush glass packs, but I've heard they cause even more raspiness.
VQ35maxima=Beast is offline
Old 11-29-2016, 10:51 AM
PowerTotheMax's Avatar
30" magnaflow resonator would do the trick. Not sure exactly which part#
PowerTotheMax is offline
Old 12-01-2016, 09:00 AM
TSelanne's Avatar
magnaflow #12641. This is what I used. You'll have to remove your center brace in order to get it to fit.
However with a stock cat and 2.5" catback I'd suggest the #12640. I have this one too on my other max. This will fit behind the brace (barely).
With either one you'll have to chop off a few inches from the start of your bpipe before it makes the first bend. Which is no big deal. You can weld it there or put in a flange. I'd suggest a flange in case you ever want to remove/replace the res in the future.
Neither of these are raspy for me and they'll help with drone. What muffler you running?
TSelanne is offline
Old 12-01-2016, 10:55 PM
Well that's the thing, I have a full 2.5 inch straight pipe, but I have a flange right behind the axle so I can interchange from straight pipe, and stock muffler. But I'm looking for something to use with no muffler, just res, I kinda like it loud, but want a different sound.
I found a resonator on eBay that looked interesting, I will link it, let me know what you think.
https://www.ebay.com/itm/272433312781
Old 12-02-2016, 10:14 AM
That's Mr. Detail to you
Scottwax's Avatar
Dynomax is pretty good too.
Scottwax is offline
Old 12-02-2016, 06:27 PM
which series would you recommend?
Old 12-02-2016, 10:17 PM
george__'s Avatar
That gigantic magnaflow #12641
george__ is offline
