5 gen IACV question
5 gen IACV question
Hi Guys!
I have a 2003 Max Titanium with the fly by wire TB.
I recently burned out the ECM because Front Motor Mount.
Yeah I read about it after I got the thing but forgot to discon the plug.
Is this IACV prone to shorting?
Or should I just bypass the lines anyway?
I read about it somewhere but the details are foggy after googling all day, and would like to stick one in before the ECU shows up if necessary.
I don't think it is but...
Also, can I relearn the ECM and key(s) with the Consult freeware and cable/laptop??
Thanks!
Thanks!
Update.
Drove it over to the locksmith and it ran fine with the fried Mosfet, even though the pedal was a little squishy.
Pulled the bad ECU, swapped in the new/used one when I got there.
Had the keys programmed and it took the guy about 2 minutes.
Started right up, idles rock solid, and runs like a raped ape.
Didn't have to reset the idle or anything.
As a bonus, the P1456* code that has been driving me nuts is gone.
*Small EVAP leak.
*Small EVAP leak.
MidnightI35
05-26-2017 08:47 AM
OverlakeLemons
09-22-2016 02:29 PM
