Name that noise
Old 06-21-2016, 10:52 AM
ONE BAD Maxima's Avatar
Name that noise
This just started to happen. Any suggestions? Belts are all there and spinning, AC is off, power steering fluid is full.
ONE BAD Maxima is offline
Old 06-21-2016, 11:19 AM
Donkeypunch's Avatar
Straight pipe?
The ticking noise, or that loud bang?
Donkeypunch is offline
Old 06-21-2016, 11:29 AM
dot dot dot ...
NmexMAX's Avatar
A lot of weird an unnatural noises going on there.
NmexMAX is offline
Old 06-21-2016, 11:31 AM
That ticking/bang was the MEVI (or whatever it is called) opening. more of the whining....
I will have to take a much better video...
Old 06-21-2016, 12:25 PM
mclasser's Avatar
Maybe the PS pump or alternator. See if the whine worsens when turning the wheels or with the lights & A/C on. Definitive test is running the car with both belts off.
mclasser is offline
Old 06-21-2016, 02:10 PM
nestorlugo's Avatar
Thread title
This is a great idea for a game show!
But seriously like mclasser said you can try taking off the compressor and alt belt first to rule those out than follow by taking the Ps belt
nestorlugo is offline
Old 06-21-2016, 02:39 PM
Derrick2k2SE's Avatar
^^this^^
Start with removing the AC belt since it's easier to remove than the PS belt. If it still makes a noise then continue with the PS belt.
Derrick2k2SE is offline
Old 06-21-2016, 06:28 PM
Originally Posted by Derrick2k2SE
^^this^^
AC belt removed, there is no noise. AC compressor is less than 2 years old, alt is less than 4. Could it be the ldeler pulley? Have a better video, trying to post it.
New video
[youtube]_OQ7Ew8U-kI[\youtube]
https://youtu.be/_OQ7Ew8U-kI
Old 06-21-2016, 08:15 PM
maxiiiboy's Avatar
Can't help you - use a stethoscope to pinpoint the noise.
They are only ~$5 at Harbor Freight.
maxiiiboy is offline
Old 06-21-2016, 10:41 PM
You've pretty much narrowed it down to three components. Give each one a spin and see how they feel. The tensioner pulley should spin smoothly with no vibration, chattering or side to side movement.
Old 06-22-2016, 06:33 AM
Montego Murph's Avatar
I listened carefully -- it sounds like there's a small child in there!
Montego Murph is offline
Old 06-22-2016, 07:58 AM
mclasser's Avatar
From the second vid, my money's on a bad idler pulley. Eric the Car Guy did a video of an old Altima with a bad IP; whined like yours.
mclasser is offline
Old 06-22-2016, 09:27 AM
Prophecy99's Avatar
sounds like an alternator kinda whinning to me
Prophecy99 is offline
Old 06-22-2016, 09:29 AM
I have to make a clarification just to be clear and avoid any confusion.
An "idler" pulley is a fixed pulley that only guides the belt. A "tensioner" pulley is either sprung or cranked into position to tighten the belt.
Out cars don't have an idler pulley. We're all referring to the tensioner pulley here.
Old 06-22-2016, 05:21 PM
Correct, and I replaced it. The noise is still there. Guess alt is next.
Old 06-22-2016, 06:53 PM
I'm sorry if I missed what you posted.
So you took the power belt off and a new pulley bearing and that's not it.
Now you're going to remove the alt belt and see what that does?
I wonder what the winning could be if it's not the alt.
I think that actually is a small child at the end of the vid. I thought it was the engine at first.
Old 06-23-2016, 03:00 AM
I removed the belt that connects the alt, AC compressor and crank pulley, and the noise goes away. I replaced the belt tensioner pulley since it was the cheapest and oldest on the car. Noise is still there. Next l am going to replace the alternator.
Old 06-23-2016, 04:25 AM
Before you replace any more parts get an automotive stethoscope. You really should have one anyway. Touch the alternator and AC to see if the noise amplifies. It would have paid for itself several times over just on the tensioner. Trust me, they really work.
http://www.harborfreight.com/mechani...ope-69913.html
Old 06-23-2016, 03:28 PM
maximatech12's Avatar
Originally Posted by nestorlugo
Thread title
It could be an AM radio show
This whine gets louder as the engine revs.
It sounds like pulley misalignment but wouldn't that result in a squeal/chirp?
Maybe it's just as simple as belts too tight. Did you set them to 30lbs/rib?
Consider taking the time to check the pulley alignment.
maximatech12 is offline
Old 06-23-2016, 08:31 PM
There is no "pulley alignment" on these cars so I'm not sure what that would sound like. The components bolt in place with no room for adjustment or alignment.
Old 06-24-2016, 08:25 AM
It could be a noisy water pump .
Old 06-24-2016, 09:09 AM
mclasser's Avatar
Before jumping to expensive conclusions, keep it simple. A cheap stethescope will isolate a bad accessory item, which is most likely OP's issue. The water pumps last a very long time on these cars.
mclasser is offline
Old 06-24-2016, 12:00 PM
VQ35maxima=Beast's Avatar
Is the belt rubbing on anything? I guess that's possible lol
VQ35maxima=Beast is offline
Old 06-24-2016, 12:34 PM
Please stop taking wild guesses and wasting the OPs time. This is starting to get silly.
He clearly stated that the noise went away when he removed the belt. How could that possibly point to a water pump?
Old 06-24-2016, 12:38 PM
Bad *** Newb
Child_uv_KoRn's Avatar
How dare you question a self-proclaimed a33 tech that uses Firestone for car repairs!
Child_uv_KoRn is offline
Old 06-24-2016, 01:57 PM
nestorlugo's Avatar
Old 06-25-2016, 06:18 AM
It sounds like the famous p/s pump noise associated with bleeding the p/s system but the main drive belt was removed and the sound went away? How can you remove the alternator belt and run the engine? Off of another battery?
The p/s pump buzz has not yet been illustrated too well here on the org.
Old 06-25-2016, 07:07 AM
cornholio's Avatar
iirc ps runs off a different belt than the one OP removed to isolate the noise, so why would it be the ps pump? that doesn't make sense to me
cornholio is offline
Old 06-25-2016, 10:52 AM
You've never heard any of these sounds yourself so just stop.
Any car can be run and driven without the alternator as long as the battery holds out. Without headlights that could be quite a while. How does a "tech" who offers so much advice not know something so basic?
Old 06-25-2016, 11:46 AM
Well the alternator bearing is only 30 bucks. You can just replace that if it's an alternator. It can be damaged by a belt being overtightened.
The P/S pump takes on a whining noise and yes I have it now but it's beginning to break up. But that's another thread.
So the P/S hose is very similar to the AC low pressure/high pressure hose. if the P/S pump whines then the Compressor could whine from a similar reasons.
Like Maxiiiboy said I'd get the scope and pinpoint the exact location of the noise then find the reason.
The hoses have a braided hose wrapped in rubber. The braids may be to absorb air bubbles but I'm not an engineer I dunno.
Old 06-25-2016, 02:45 PM
nestorlugo's Avatar
Old 06-25-2016, 03:54 PM
For the convenience of everyone reading, I've highlighted the parts of your statement that aren't complete fantasy.
Old 08-31-2016, 05:30 PM
Well, it was the alternator. Went out last week. It was almost 3 year's old. Had a lifetime warranty so I am back in business. Thanks to all that helped.
KeizerDad
02-24-2018 09:19 AM
dadsmax
06-23-2017 07:42 PM
Philobetto707
06-21-2016 05:05 AM
carguy96
06-12-2016 09:39 PM
gonzonyc
06-02-2016 07:39 AM
Quick Reply: Name that noise
