Penzoil platinum high mielage 5w30 or penzoil ultra platinum?
Old 06-04-2016, 05:05 PM
Maxboy23's Avatar
Im due for an oil change and trying to figure whats the best oil i should get for my 02 maxima it has 166k on the dash i hear tbe penzoil are really good for our motors I had royal purple but my motor burned it like crazy
Maxboy23 is offline
Old 06-04-2016, 05:17 PM
Bad *** Newb
Child_uv_KoRn's Avatar
Pennz is a burner, apparently. Used pennz ultra 5w40 last OC in sister's de-k. That motor doesn't burn oil, but 1.5 quarts disappeared in about 7k miles. It yields good UOA, but VQs don't seem to care.
Mobil 0w40, castrol 0w40, w/e group IV.
Also, I'm sure your precats are happy to be accelerating the burning.
Child_uv_KoRn is offline
Old 06-04-2016, 07:44 PM
mclasser's Avatar
^^+1 on Mobil 1 0W40. Smooth, quiet oil that only needs a 1/2 qt top off in my 7,000 mile runs.
mclasser is offline
Old 06-04-2016, 09:02 PM
Maxboy23's Avatar
0w40 might give it a shot never used that before i was also thinking of mobil 1 high mielage oil 10w30
Maxboy23 is offline
Old 06-05-2016, 12:35 PM
maxinout93's Avatar
Does the thicker oil decrease gas mileage? Mobile 1 0-w40?
maxinout93 is offline
Old 06-05-2016, 12:37 PM
Bad *** Newb
.2 mpg lol
That's why car manuf changed to 20 weight and lied to everyone. It saves them on cafe ratings. It's a scam. Nissan won't do it b/c they know VQs shear oil hard.
Old 06-05-2016, 01:45 PM
nestorlugo's Avatar
I'm gonna give the 0-w40 a try in this upcoming North Texas heat! Well see how it goes
nestorlugo is offline
Old 06-05-2016, 02:32 PM
Bad *** Newb
It's a very stable oil and should perform great for you. Get an UOA for us to see XD
Old 06-05-2016, 04:30 PM
sebastian2041's Avatar
Make sure its european formula! The other mobil 5w 30 is trash btw
sebastian2041 is offline
Old 06-05-2016, 08:54 PM
nestorlugo's Avatar
Definitely will!
Taking PayPal donations for those waiting on results!
Old 06-05-2016, 09:25 PM
maxiiiboy's Avatar
Why do you think so?
I have been using Mobil 1 5W-30 for about 10 years, changing oil every 5,000 miles. I have no complaints. My car is running just fine, with no measurable oil consumption at 135k miles.
If you think there is better oil than the M1 5W-30 I am using, I would like to know. I am open-minded and willing to change but would like to know why you think M1 5W-30 is trash. (BTW, I am already planning to change to M1 0W-30).
maxiiiboy is offline
Old 06-05-2016, 09:48 PM
Bad *** Newb
UOAs are very meh for normal OCI to bleh for extended OCI. It's a very plain hydrocracked oil. Also, barely being a 30 weight, it shears to a 20 very quickly.
5k miles is the most you'd want to run it and even then I doubt it's giving very good results. Castrol syn blend is probably better.
Check the Z thread of UOAs. EVERYONE quit using it. It's very subpar compared to real synthetics.
We were just talking about what oil to use. Switch.
Old 06-06-2016, 07:11 AM
Prophecy99's Avatar
AMSOIL (ASL) 5w-30 Signature Serious is something I am looking at too, guys on here have had much sucess in minimizing burning with that.
talkinghorse here sells it directly
Prophecy99 is offline
Old 06-06-2016, 07:15 AM
Prophecy99's Avatar
https://maxima.org/forums/5th-genera...ml#post9047398
decent success stories with the amsoil
Old 07-01-2019, 11:01 AM
Prophecy99's Avatar
so what are the pros and cons to switching to high mileage oil? i started changing my own oil now and started to think about switching to high mileage, i am at 230k as of today. used nothing but conventional up to this point.
is it worth it? will i see less burning? (cats have been gutted for 50k and were 100% intact when i gutted them) what are the cons? can i dump regular into it and mix it if in a pitch when replacing any burnt amounts inbetween OIC ?
Old 07-01-2019, 12:24 PM
Donkeypunch's Avatar
i actually did an oil analysis with penz plat 10w30. 5k miles.
The oil itself had much more life left though.
Lead is still a bit high for your Maxima,
but the good news is that it's steady.
If it shows poor bearing wear, at least it isn’t getting any worse.
Sometimes we find extra metal like this and it turns out to be normal
for that particular engine and how it's used,
so maybe that's the case for your Nissan.
We'll watch lead from here and let you know if it looks like trouble.
Potassium is low enough to show no coolant,
and silicon shows good air filtration at 15 ppm. No fuel was found.
The TBN was good at 2.7, but stick with 5k mile intervals to monitor bearing wear.
so.... not the best oil or at least the vq is super hard on oil, or i need to go to a thicker oil, or a thinner W like a 5w.
idk, going to change brands next oil change and see if that protects the bearings better.
interesting read.
https://my350z.com/forum/engine-and-...-and-info.html
Donkeypunch is offline
Old 07-01-2019, 01:08 PM
maxiiiboy's Avatar
High Mileage (HM) oils have additives that swell/rejuvenate seals, and thus minimize/avoid oil leaks.
There are no significant cons that I am aware of.
Old 07-03-2019, 09:33 PM
https://www.bobistheoilguy.com/forum...at#Post5150835
lets see what they say about PP.
i saw a guy on that Z thread post an mutol sample that had crazy bearing wear and stopped when he changed oils.
hopefully, for me, our engines don't like PP.
osetleo
11-07-2018 02:23 PM
JwaxMax99
Fluids and Lubricants
28
05-04-2015 08:22 AM
nselca2
18
07-05-2011 01:27 PM
hotrodder
21
03-06-2010 07:27 PM
PoLo
09-13-2002 08:02 PM
Quick Reply: Penzoil platinum high mielage 5w30 or penzoil ultra platinum?
