Gutting rear pre-cat, gaskets needed?
Finally popped the code for the rear precat. Want to gut it out, and don't want to deal with trying to do it without removing it. I know front had a crush gasket that needed to be replaced when I did that, just seeing if the rear does also, how many, and what part # if someone has that handy.
I was going to say that it was the same P/N but courtesy nissan is showing that they are different. Here is the link to the parts page http://www.courtesyparts.com/auto-pa...omponents-scat
I don't think it's possible to do it without taking it off depending on what spec you're driving, also can't remember when nissan did the whole switchover to a regulated emissions. Says you have a 00 so I could be wrong.
Child u have a saved URL on a DIY how to gutting precats on a 5.5 gen (2002) haven't had any issues with cats yet but I've been reading all your comments on them and it's terrifying, not ready to dump $ into headers ypipe and exhaust just yet...
The Rear is usually very intact and solid. I would definitely remove it from the car. I used a half inch drill bit and put as many holes as possible in it. Then chiseled to break into pieces small enough to fit the opening. Just drill and chisel until the chunks come out. It's time consuming, though.
My inbox is open, now :|
K sounds good, I have all tools so shouldn't b too bad, just finding time is a chore more than anything, rust isn't too bad either...I'm watching some YouTube vids to, can I leave o2 alone? Or will I have to take that out and do something with it (precat)
So anyone know where to get replacement screws just in case the bolts break off? Is the Dealer the only option? replacement screws for the front and rear pre cat. front pre cat top bolts/ and rear pre-cat bottom bolts.
Search defouler and nonfouler on here/google. That's what you have to use to trick the ECU.
2014Maxima
04-23-2016 04:57 PM
Jason B
03-12-2016 09:25 PM
reallywildstuff
02-25-2016 12:10 PM
