Camshaft position sensor issue
So quick run down of whats been going on.
My car has been doing this weird ilde drop like it wants to stall and then it started shutting off on me every now and then. every so often it can take a little while to start up. So i read up on it and i presume camshaft position sensor. My tranny started giving issues so i decide to change that out first. Car is running tranny seems fine so far.
i decide to buy the cam shaft sensors and crank shaft sensors from auto zone since i blew nearly 1k on getting the tranny and bushings right. i change out the cam shaft sensor but not the crank yet but cleared the code and drive the car and it seems fine fot the initial drive.
then the bogging came back and now it is hard to start again but this time I'm not getting a code, would changing out the crank position sensor fix the issue or is my issue somewhere else?
If you buy the CPS you could return it if it doesn't work. Just keep it really clean
I advocate junkyard everything in these cases LOL. They're small and become gifts :P
Same issue you had, Thank God for AAA lol because I was stranded on saturday with this problem. Mines was the cam shaft sensor, crank sensor, and needed spark plugs.
I also cleaned the trottle body just to be on the safe side. be running fine every since.
Hope this info helps.
Unplug crank sensor and see if the bogging happens. If doesn't, then I'm betting maf. CPS and MAF are tricky ****ers.
hahaha i haven't ran into any maxims yet at the junk yard.. i should start looking harder. but i did change my crank sensor and found metal shavings on it. i have to test the car out today to see if that helped. then ill check the maf.. luckily i have an extra one
kingkai1990
11-17-2015 12:36 PM
Dolphinride
11-08-2015 07:00 PM
floppy_disk
10-29-2015 09:58 AM
