Synthetic gear oil question
Old 01-08-2016, 03:56 PM
losifanatic's Avatar
Ok I have the Jim Wolfe Technologies lightened flywheel and clutch that I'm installing. I need to get some new gear oil.
My girlfriend works for napa and can get Synthetic gl-4 valvoline 811095 mtf for a great price. I was told when I had my sentra ser spec v not to put anything other than redline synthetic in a nissan transmission. I can get the valvoline for 1/2 the price of the redline mt-85. Will the valvoline work just as well as the redline?
losifanatic is offline
Old 01-08-2016, 04:01 PM
Bad *** Newb
Child_uv_KoRn's Avatar
Redline or amsoil ONLY unless there's another high vis oil.
Viscosity is way too low on everything else when I looked.
Check the ratings. Valvoline MTF is 8.8 cst, yikes. Even the redline 75w85 is 12.0. Red/Ams 75w90 is 14.7, iirc. That's why we go with the 90 unless you live in canada or something.
And for reference to anyone that's not aware - NEVER USE GL-5! It will eat the synchros.
Child_uv_KoRn is offline
Old 01-08-2016, 06:00 PM
Derrick2k2SE's Avatar
Just go with the good stuff. It's more expensive but the 6-speed doesn't hold much and it'll be good for years. It'll also shift better.
Derrick2k2SE is offline
Old 01-08-2016, 07:07 PM
SLOW
Nealoc187's Avatar
i like and use redline MT90. truthfully you can put whatever you want, even incorrectly specced GL5, and you'd probably be okay for tens of thousands of miles, it's not like improperly specced trans oil will cause a trans failure next week, but you might as well use properly specced good stuff and not worry about it. not hard to get your hands on tried and true oil.
Nealoc187 is offline
Old 01-09-2016, 05:09 AM
Redline it is then.
Old 01-09-2016, 05:22 AM
4.8 quarts is what I was told
Old 01-09-2016, 06:28 AM
Bad *** Newb
3 qts should make it start overflowing. I tilted mine and still couldn't fit the last bit.
Old 01-09-2016, 05:48 PM
I believe the 4.8 is for the 5-speed. The 6-speed is definitely less than 3 quarts.
Also, don't try and add more than it will hold. Once it pores out, stop and install the plug. Adding too much could possibly cause the axle seals to leak and will not give you any benefit.
Old 01-09-2016, 05:55 PM
I just ordered 3 quarts of MT90 from here for $43.83 shipped. It's usually at least $17 per qt or more plus shipping.
http://www.ebay.com/itm/172026872298?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Last year I had the tranny out and intended to reuse the MT90 that was in it but I let it get contaminated and couldn't use it. The only GL4 I could find locally was from the Nissan dealer. It hasn't shifted as well since then and this thread just reminded me I need to get back to the MT90.
Old 01-09-2016, 08:23 PM
Ordered a pack of 4 of the mt-85 for 60.00 shipped.
The_Fixer
04-12-2017 06:34 AM
cols
08-26-2016 10:53 AM
saleenssc
01-18-2016 11:43 AM
george__
01-13-2016 07:26 PM
03Alt3.5Biz
01-08-2016 08:58 PM
Quick Reply: Synthetic gear oil question
