Wheel bearing or end links?
Old 04-22-2015, 02:15 PM
Curb Rash Repair 100 a wheel
Maxima112's Avatar
Hi all! So I've been having this knocking type noise from my passenger side wheel well area that happens mainly when I accelerate. At times its during a turn, or straight, doesn't really matter. I also hear it some times at very slow speeds coming up to a red light at around 5-10MPH and I'm off the gas and break. I do not hear any humming at all, just the knocking and when it gets really bad I can actually feel it under the floor on the driver side closest to the center of the car.
For example, I could be on the freeway at 60 or 70 and I'll hear the starting of the knocking and immediately when I am off the gas, the noise goes away and right when I'm back on it, the knocking continues, until I go up to maybe 80, then it stops for the most part but on and off here and there. I though it was the tie rod ends, I changed them yesterday and the problem is still there. I have Mogg end links that I changed many years ago, could it be that? Any way to test the end links? I want to try the cheaper options first, suggestions?
THanks!
Maxima112 is offline
Old 04-22-2015, 03:06 PM
Mattx's Avatar
How about your inner tie rods? Have you tried jacking car up and seeing if you have any play side to side and at 12 and 6 on the wheel. In other words grabbing at 12 and 6 wiggling wheel and checking for play same for 9&3?? While you're at it check ball joints.
Mattx is offline
AcuraLegend
10-17-2016 08:47 PM
AcuraLegend
09-22-2015 04:22 PM
TheMafia
09-04-2015 08:26 AM
maximusrising
09-02-2015 09:55 AM
coasterswim
09-02-2015 07:43 AM
Quick Reply: Wheel bearing or end links?
