Calipers 02 opinion
Calipers 02 opinion
So I want to upgrade my calipers all 4. at first I had the Power Stop in mind, the red coated ones. But now I'm changing my mind, I want to go with these type of calipers but they are semi-loaded (i dont know what that quite means) and remanufactured. Is there any wrong being remanufactured. Does anyone know if this comes with the brackets? BECK/ARNLEY Part # 0771563C Google it up and click on rockauto's website. Also, is this a good product? I'm looking for performance. I already have Power Stop brakes and rotors installed.
The rear callipers are all GARBAGEeee.... Buy something with lifetime warranty!! Fronts supposedly okay, I used gen 6 power stop callipers for the front and they have out lasted the rear callipers. The gen 6 callipers were used due to big brake mod, they are direct bolt on and fits the 17" rims .
Here's an option for the rear https://maxima.org/forums/advanced-s...de-option.html
I do have the 17" stock rims and 18" rims that I will use in the future.
So if I do get the 6th gen calipers, do I need to change my rotors? Can I use the same brake pads from 5th gen? Do I need any other things to go along with it?
search 6th GEN BBK and those only are for the fronts, rears you are out of luck for anything practical unless u have $$ to blow.
and to answer directly 6th Gen Calipers go with 6th gen rotors and pads.
I got the calipers and shims you'll need to get rotors amd pads...
04-16-2020 05:15 AM
REDinLV
10-18-2015 05:31 AM
imported_Nismo_max
09-21-2015 07:24 PM
dvcamp
09-18-2015 10:17 AM
