big problems with gen 5 wont start
Old 02-04-2015, 03:20 PM
phill's Avatar
ok so i was in my driveway and the airbag light started blinking which has never happened so i shut the car of and now it wont turn over at all just keeps clicking the steering wheel is hard to turn and the brake pedal wont go down??? not sure quite what just happened and would appreciate any insight into what this problem may be! thank you- phill
phill is offline
Old 02-04-2015, 03:33 PM
chrome91's Avatar
is the serpentine belt still intact?
chrome91 is offline
Old 02-04-2015, 06:12 PM
mclasser's Avatar
Year/mileage on the car?
mclasser is offline
Old 02-04-2015, 09:30 PM
maxiiiboy's Avatar
It seems there is a problem with your airbag and/or the security/restraint system. After you did shut off the car, the problem now prevents your car from starting. The problem may be caused by a mechanical failure, or perhaps the car was in an accident and it wasn't fixed properly. You may find more on http://www.airbagsolutions.com/vehicles_list.aspx, but it will cost you at least $14.95. There is some free background information on https://answers.yahoo.com/question/i...4143131AAuA6fm
maxiiiboy is offline
Old 02-04-2015, 09:38 PM
nestorlugo's Avatar
Have you tried to jump start? Battery probably died...
Any work done lately?
nestorlugo is offline
Old 02-05-2015, 12:01 AM
DennisMik's Avatar
If the engine doesn't turn over, you may have a dead battery or a bad ignition switch.
Start by getting a voltmeter and see if the battery has 12 volts. If it has less than 12, it is discharged. You can try getting the car jumped if the battery is discharged. If the car starts, are the BRAKE and BATTERY lights in the dash on? This would indicate the alternator is not charging the battery.
Check these things and report back. Also let us know what year your car is, because all the years are not identical.
DennisMik is offline
Old 02-05-2015, 12:27 AM
fastdriver247's Avatar
air bag light
I've had my 2000 se do similar and i started with most likely cause .no wreck and no recent work ,possibly a fuse .as it turned out it was a fuse for ignition and alternator went bad which was the reason for air bag light. My dash cluster went a lil bonkers ,along with everything else including my brakes being stiff. Hope this may help
fastdriver247 is offline
Old 02-05-2015, 01:08 AM
Max_5gen's Avatar
Posts #5-7 list most probable causes for your troubles. I'd start from checking the battery voltage or simply try to jump start the car. Steering wheel and brake pedal being stiff are simply consequences of the engine not running, don't worry about them.
Max_5gen is offline
Finkle
09-27-2015 09:53 PM
MaximaDrvr
08-19-2015 08:20 PM
2k0to2k3
08-18-2015 09:59 AM
Gsantos79
08-08-2015 07:41 AM
yat70458
08-03-2015 01:16 PM
Quick Reply: big problems with gen 5 wont start
