Please help 02 maxima overheating before even turning car on after sitting over night
Old 01-28-2015, 11:19 PM
drsfinest81191's Avatar
please help 02 maxima overheating before even turning car on after sitting over night
Hi maxima community I am having this "overheating" situation on my 2002 maxima. This is what is happening. The car can sit hours, over nights etc and when I go to acc with my key NOT TURNING the engine over at all. As soon as I do that the temperature gauge automatically just shoots up to over heating and fans don't come on until I try to start it and it doesn't start on first try. The fans go on blast both of them and never shut off. No leaks radiator has always been full. I am leaning towards a thermostat or a clogged radiator. When it does start it never starts with the right RPMS to warm the engine up. Its also in limp mode. What do you guys think? Thank you !
drsfinest81191 is offline
Old 01-29-2015, 08:11 AM
Bump anybody? ?
Old 01-29-2015, 08:23 AM
nestorlugo's Avatar
Has the thermostat been changed before?
Any codes?
Check the coolant temperature sensor per thr fsm...
nestorlugo is offline
Old 01-29-2015, 08:40 AM
Any codes?
I don't know if the thermostat has been changed I've had the car for about a year and a half never any issues.
I don't have any codes besides 2 p0011 and 2 p0051 codes. One is for 02 sensor and the other is ivt selonoid.
My car doesn't have a coolant temperature sensor well I can't find out in the fsm.
Old 01-29-2015, 08:55 AM
dot dot dot ...
NmexMAX's Avatar
http://www.nicoclub.com/FSM/Maxima/2003/ec.pdf
EC-208, 209, 210, also show's where it's located.
NmexMAX is offline
Old 01-29-2015, 09:15 AM
Awesome. I never read anything about it and never found it in SECTION HA of the fsm where I assumed it was. But thanks any way to test it with out using anything fancy?
Old 01-29-2015, 08:37 PM
DennisMik's Avatar
Depends on your definition of fancy. You need a volt/ohm meter. A cheap one is $5 and a decent one is $25. If you don't all ready have one, I would recommend that you get one with the "auto ranging" feature. Auto ranging makes it much easier to use.
Then look at page 207 in the link that NmexMAX gave you. There is a resistance/temperature scale for the ECTS. If the engine is cold at say 25º F, then the ECTS should have a resistance reading of around 6K ohms. In your case, I bet you will get a reading of around 100 ohms.
DennisMik is offline
Old 01-30-2015, 12:38 AM
dch95's Avatar
If you turn the car to ACC after you know for a fact the engine is not hot but the gauge reads hot after doing this, the problem is the sensor that controls your dash gauge. I can't remember which sensor this is but I believe that this sensor also tell the ECU that you are running hot and the ECU turns on fans accordingly. Do a search on this sensor and see what you come up with. Its not a mechanical problem but an electrical problem.
dch95 is offline
Old 01-30-2015, 12:54 AM
Max_5gen's Avatar
Spot on- page EL121 FCM shows ECTS is connected to ECU (they call it ECM) and then ECU drives the gauge. As others suggested most likely ECTS went bad and decreased its resistance making ECU 'think' that the engine is 'hot' causing all the problems you described. ECU would turn on the fans, make AFR lean and engine harder to start and possibly put it in limp mode to prevent overheating.
Max_5gen is offline
Old 01-30-2015, 08:24 AM
Thank you guys for everything ! I really appreciate it iam going to test it out today or tomorrow and report back and let you guys know.
Old 01-30-2015, 02:18 PM
Nopike's Avatar
That sensor is probably pretty inexpensive and should be relatively easy to change. If you are not sure if the old one is bad you may want to change it anyway. There is a very good chance that the sensor is causing your problems. Although if the sensor was faulty I would expect a trouble code to be activated.
Engine coolant temperature sensor
(P0115, 0103) (P0125, 0908)
Nopike is offline
Old 01-30-2015, 05:21 PM
Yes I thought I would get a code too but guess not. I already took the old one out really easy. I was going to pick up the new one but Nissan parts department closed early today. So tomorrow I will get the new one.
Does anyone know if the 00 01 maxima engine coolant temperature sensor is the same? I wanted to try my sisters sensor since it's so easy to uninstall and install.
Old 01-30-2015, 05:24 PM
On a side note I called nissan to see the price and I didnt have the Vin on me he said it's $60-$80 when advance auto parts and Napa auto parts sell it for $25-30$
Old 01-30-2015, 06:29 PM
nestorlugo's Avatar
Perhaps you can ask for the 00 01 pn at the autoparts store
Old 01-30-2015, 09:31 PM
Nopike's Avatar
Can't say for sure but I would expect 2000-2003 to all use the same sensor. I would just buy the sensor from Napa not from the dealer. Or even consider a junk yard you could get it for a few dollars.
Nopike is offline
Old 01-31-2015, 11:37 AM
Bad *** Newb
Child_uv_KoRn's Avatar
step 1: go to junkyard
step 2: pocket a few sensors just to be sure
step 3: ????????
Step 4: PROFIT
Child_uv_KoRn is offline
Old 01-31-2015, 05:59 PM
DennisMik's Avatar
The ECTS is the same for 1997 to 2003.
Its Nissan part # is 22630-44B20
The Nissan MSRP is $41.33
I don't have any nice things to say about the op's dealer.
Old 02-01-2015, 09:24 AM
I'm kinda starting to stay away from napa since they say online their high pressure hoses are oem but they aren't I have a leak where the hose connects to the pump. It's a slow little leak but I should of just went oem.
Old 02-01-2015, 09:26 AM
step 3: ????????
Step 4: PROFIT
I might just do that pocket it and pay for something big that I need lol.
Old 02-01-2015, 09:29 AM
Thanks a lot dennis I was just about to ask for the part number lol. In the future if I need a part number for a part where can I find it?
Old 02-01-2015, 09:44 AM
nestorlugo's Avatar
courtesynissanparts.com
Old 02-01-2015, 06:07 PM
Thanks bro
Old 02-08-2015, 04:36 PM
Fixedd
I want to let you guys know it's fixed! Thanks to you guys. I inspected the ECTS it looked old so I ordered a oem ENGINE COOLANT TEMPERATURE SENSOR (ECTS) from eBay for 26$ (dealer was 46$) i installed it and it's all perfect again. Now to fix my p0011 ivt solenoid Valve code. I'm going to clean them with brake cleaner like other .org members who successfully fixed the code. I have them out already.
Old 02-08-2015, 07:16 PM
nestorlugo's Avatar
Lakersallday24
06-16-2019 01:35 AM
Samedi
08-13-2015 04:05 PM
dauntlessmax
08-05-2015 10:29 AM
egali045
08-05-2015 09:02 AM
wpr
08-05-2015 03:28 AM
Quick Reply: Please help 02 maxima overheating before even turning car on after sitting over night
