01 Maxima having trouble starting, please help!
Old 12-09-2014, 08:25 PM
ace333's Avatar
I recently bought an 01 AE Max (currently 47k on it) and now that it's gotten colder starting it has become more and more difficult. Generally, I'll try starting it and it'll crank just fine and start after 3 or so cranks. It'll get up to around 1k rpms and die. I'll restart it and it'll restart just fine getting to around 1.5k rpms. I thought it was just my battery not giving enough current so I replaced it. That didn't really change anything so I figured it was maybe a fuel problem. I changed the fuel filter (what a PITA) and now acceleration is better, but starting it isn't any easier. Sparkplugs were replaced as preventative maintenance also. The alternator is only a year old as well. Not really sure what else it could be, and I really don't want to keep throwing money at this.
ace333 is offline
Old 12-10-2014, 06:24 AM
i1k
i1k's Avatar
CEL on? Did you pull any codes?
i1k is offline
Old 12-10-2014, 08:05 AM
ace333's Avatar
Nope no codes
ace333 is offline
Old 12-10-2014, 06:02 PM
maxiiiboy's Avatar
OK, what happens next? When you give it gas, will it get above 1.5K RPM? Will it keep running or does it die? Or what?
Looks like your battery is OK. I would suspect one/more of (Fuel Pressure Regulator (FPR), FP Relay, Fuel Rail) and/or the Crank Sensor. Also, perhaps your fuel injectors are clogged; adding a fuel injector cleaner to your gas is a reasonable precaution. Finally, can you tell whether the car does not have enough fuel, or whether it has too much fuel and is flooding itself (gas smell would indicate).
At any rate, if you want help, you need to give us a better description; see my questions above.
maxiiiboy is offline
Old 12-10-2014, 06:59 PM
jetman's Avatar
you may have a problem with your mass air flow sensor.
jetman is offline
Old 12-11-2014, 07:10 PM
ace333's Avatar
Yes, when I give it gas it'll go above 1.5k rpm. It stays running after. FP relay should be fine, checked it when I did my filter. And I put in some fuel injector cleaner already.
ace333 is offline
Old 12-11-2014, 08:00 PM
maxiiiboy's Avatar
OK, do what Jetman suggested - check/clean the MAF.
Old 12-11-2014, 08:22 PM
Bad *** Newb
Child_uv_KoRn's Avatar
one of the crank sensors
Child_uv_KoRn is offline
Old 12-11-2014, 08:34 PM
ace333's Avatar
sorry, forgot to say that I took the MAF out and it didn't look dirty at all, not sure though since it's kind of hard to see
ace333 is offline
ace333's Avatar
is there anyway to know which one?
ace333 is offline
Old 12-14-2014, 12:24 AM
Max_5gen's Avatar
Since you can maintain RPM 'manually' I'd try to clean throttle body first, esp butterfly plate. At idle the plate is almost closed and if the dirt got there over time it won't let enough air through and engine will die.
Max_5gen is offline
Old 12-14-2014, 05:34 AM
george__'s Avatar
Don't ever ACTUALLY TOUCH IT.
george__ is offline
Old 12-14-2014, 08:16 AM
jared21927's Avatar
check the crankshaft sensor. replaced mine this week. starting problems suck because there can be so many causes.
jared21927 is offline
Old 12-14-2014, 10:53 AM
maxiiiboy's Avatar
So, let me sum it up: The problem is that the car does hold idle. Once you give it gas, it runs OK.
Given this problem description, I suggest the following:
  • Clean or replace your MAF ($77 from Courtesy Nissan). Re. cleaning, MAF cleaner is about $13 from most shops. There is a post "how to clean your MAF under $10" or, something like that, on this forum. However, cleaning will not help if the MAF itself is worn out. In either case, just inspecting it, as you did, is not sufficient. I would just replace it.
  • Your IACV may be at fault. If it were, you should see P0505, but perhaps not. The FSM tells you how to test the IACV.
Start with the MAF. It's much easier to get to, and much cheaper to replace. Also, it is the more likely source of your problem - my car had the same issue and replacing my MAF fixed it.
Slamrod
04-10-2016 05:24 PM
02PearlSE
10-07-2015 02:12 AM
laparka66
08-06-2015 09:36 AM
dauntlessmax
08-05-2015 10:29 AM
Jcof88
08-03-2015 10:43 PM
Quick Reply: 01 Maxima having trouble starting, please help!
