Oil Pan using RTV vs Gasket?
Old 11-20-2014, 01:03 PM
FrankY2K2's Avatar
So my oil pan needs to be replaced. Rusted, busted and leaking oil. Plenty of how-to threads in searches.
But my question is, whats better? Using a gasket, RTV silicone, or both?
Seems like the FSM says to use just RTV. But I read others saying the gasket is better at staving off leaks.
Any opinions? Thanks in advance.
FrankY2K2 is offline
Old 11-20-2014, 01:19 PM
Puerto Rico-Maxima Lover
Lontar1's Avatar
use the OEM gasket... no headaches
Lontar1 is offline
Old 11-21-2014, 09:02 AM
Y2kMaxima's Avatar
Originally Posted by lontar1
use the oem gasket... No headaches
+1
Y2kMaxima is offline
Old 11-21-2014, 09:18 AM
Fakie J Farkerton's Avatar
My Oem gasket was RTV. Lol
Fakie J Farkerton is offline
Old 11-21-2014, 09:19 AM
tosheto's Avatar
Different people will tell you different things. I have seen people use both with success. You decide what is better. I would put RTV on it.
tosheto is offline
Old 11-21-2014, 03:25 PM
Blassmasta's Avatar
Went the old school way
FWIW,
I just recently did this job myself and I decided to go with the paper/cork (or whatever the heck it's made of) vs the RTV.
RTV is great for the robot assemblers on the line but a bit of a pain for the DIY'er laying on his back on the garage floor. I used RTV when I did the water pump / timing chain tensioner because there was no other option. Came out fine.
BUT - when I saw there was an aftermarket 1 piece gasket for the oil pan I decided to give it a try. Neater, simpler and no stupid tube of left over goo sitting in my toolbox.
Cleaned everything up, torqued it down to spec (+2 more ft/lb taking into account gasket squish), RE-torqued 2 hours later (make sure you follow the pattern in the FSM) and so far ... perfect.
I recommend replacing the washer behind the oil cooler while you are there. They leak don'tcha know.
Easy job really.
Blassmasta is offline
Old 11-21-2014, 05:10 PM
Bad *** Newb
Child_uv_KoRn's Avatar
You still need to use RTV on a gasket...so, yeah. You might as well use RTV only and save money.
And since when does the lower pan have a gasket? I've never seen one.
Child_uv_KoRn is offline
Old 11-22-2014, 06:42 PM
Blassmasta's Avatar
Wrong.
Are you for real? Every sealing surface on a motor has a gasket of some kind. RTV or otherwise.
Old 11-22-2014, 06:49 PM
george__'s Avatar
I used the included gasket then rtv on the corners for front & rear
george__ is offline
Old 11-30-2014, 07:45 PM
vfrpilot28's Avatar
Originally Posted by Blassmasta
Wrong.
+1 and +1
vfrpilot28 is offline
Old 11-30-2014, 07:53 PM
Bad *** Newb
Wrong.
RTV, yes, but not a cork one or otherwise.
mclasser
22
11-12-2020 01:58 PM
06-06-2017 02:01 PM
05RLS2
04-14-2016 11:49 AM
knight_yyz
11-01-2015 01:34 PM
Quick Reply: Oil Pan using RTV vs Gasket?
