How to fix any 2002 - 2006 Maxima (3.5L) oil consumption/leak
Old 10-25-2014, 07:13 AM
Aviation005's Avatar
I'm tired of people paying TONS of money trying to figure out what is causing the engine to burn oil (valve covers). All of these parts will work with ANY 2002 - 2006 Maxima 3.5L and will fix any oil consumption problem you are having.
RTV (2) ($11.38):
http://www.ebay.com/itm/Permatex-Ult...0eca01&vxp=mtr
Gaskets (both) ($16.73):
http://www.ebay.com/itm/Engine-Valve...38b8a5&vxp=mtr
Front Valve cover ($45.95):
http://www.ebay.com/itm/MAXIMA-04-06...b077a0&vxp=mtr
Rear Valve Cover ($44.74):
http://www.ebay.com/itm/MAXIMA-2004-...c15162&vxp=mtr
Oil cooler O-ring ($5.86):
http://www.ebay.com/itm/NISSAN-OEM-0...42ab3b&vxp=mtr
PCV Valve ($6.74):
http://www.ebay.com/itm/Standard-Mot...f5668c&vxp=mtr
Labor: $120~
Total: $251.40
This WILL fix any oil being burned. No rebuild necessary
If you are leaking oil (after doing these repairs), check your upper and lower oil pans and camshaft position sensor O-rings (2 of them).
THIS FIXES OIL CONSUMPTION ON ALL 2002 - 2006 MAXIMA'S (3.5L)
I honestly hope this helps a bunch of people and saves them tons of money! Take care all.
If you end up replacing the rear valve cover you must buy this as the intake manifold must be removed: ($22.92)
http://www.ebay.com/itm/New-3-piece-...10b9a4&vxp=mtr
Aviation005 is offline
Old 10-25-2014, 07:35 AM
argenis69's Avatar
RTV (2) ($11.38):
PCV Valve ($6.74):
Labor: $120~
Total: $251.40
I already saved this money thanks to our fellow Maxima.org but Thank you for this info this is much more resumed and specific thread.
argenis69 is offline
Old 10-25-2014, 08:12 AM
Get Off My Lawn
Chris Gregg's Avatar
This may remedy the two primary areas where oil is known to begin leaking on these 10+ year old vehicles.
However, this DOES NOT even begin to address oil burning or consumption. Regardless of any debate as to the extent of internal factors, it is also commonly known these engines suffer from piston ring issues as well as valve seal issues.
It should also be suggested to utilize a GOOD oil catch can. I highly suggest installing one on both front and rear valve covers. Despite new PCV's, two of my three VQ35's will still vent oil vapor through the lines at both ends. Gumming up the throttle body and inside of the intake are just a couple of the consequences.
Chris Gregg is offline
Old 10-25-2014, 08:55 AM
Bad *** Newb
Child_uv_KoRn's Avatar
Werd.
PCV breathers FTW. There's almost no vacuum lines.
He missed the part out about deleting the precats
You do not need IM gaskets. Reuse the old ones. Odds are they will still seal. If not, throw them away and use a very small bead of RTV. Gaskets like that are a waste of money.
Child_uv_KoRn is offline
Old 10-25-2014, 10:20 AM
Werd.
Are PCV breathers safe? What if I take the car to 110 on the highway? Without the vacuum, will the gases escape fast enough?
Also I was wondering if someone can help me understand what is causing THIS leak. I just replaced the power steering hose (new banjo bolt) and something near the hose is leaking. (i think its oil..)
Is there an oil line that almost touches that banjo bolt?
Old 10-25-2014, 01:26 PM
Bad *** Newb
PCV is there b/c of emissions. The breather keeps the pressure equal. It will escape as necessary. Oil will probably seep out from it.
Old 10-25-2014, 01:35 PM
nismopc's Avatar
I know it's already been stated Chris Gregg, but you might want to edit this and state this will fix ONLY the valve cover gasket leak. Your generalization of it fixing any oil being burned gives 3.5 owners false hope.
This does NOT and WILL NOT fix all oil being burned or oil consumption on all 2002-2006 Maxima's.
I know first hand as do other VQ35 owners.
nismopc is offline
Old 10-25-2014, 03:23 PM
Gonna have to agree with the others. Not sure why you claim this stuff will fix oil consumption issues....
The Wizard is offline
Old 10-25-2014, 06:07 PM
any help on the leak?
Old 10-25-2014, 06:41 PM
cornholio's Avatar
did you put on new washers when you changed the banjo bolt?
cornholio is offline
Old 10-25-2014, 07:35 PM
colt149's Avatar
Check the new valve cover that you just installed for leaks. Did yo apply RTV on the critical area of the valve cover? Did you tighten the valve cover bolts :5-7 foot-lbs. Secure all the pcv valve tubing connect it to the intake manifold. Install PCV Oil Catch Can.
colt149 is offline
Old 10-25-2014, 08:15 PM
george__'s Avatar
10w30
george__ is offline
Old 10-26-2014, 02:53 AM
I had my mechanic do the anjo bolt and hose. I doubt he used new washers..
would that cause an oil leak? It looks like oil, not power steering..?
Old 10-26-2014, 10:08 AM
Anyone please? Is there an oil line near that banjo?
Old 10-26-2014, 11:57 AM
george__'s Avatar
False hope
george__ is offline
Old 10-26-2014, 05:56 PM
cornholio's Avatar
possible source of a ps leak, not oil tho. just thought it might be something to consider
Old 10-27-2014, 08:34 AM
Get Off My Lawn
Right off hand I can't recall the figures, but always make sure these are set to INCH pounds and NOT foot pounds.
Is this a new mechanic?
In any case, as best I can tell, that is oil. There are no external oil lines that high. My thought is that you failed to properly seal that rear passenger corner with gasket maker when installing the new gasket and cover. Time to pull your intake and redo the job.
Old 10-27-2014, 01:59 PM
Thank you friend. Time for 2 new covers and gaskets. Tons of rtv.
Old 10-27-2014, 02:39 PM
nestorlugo's Avatar
You should also consider the oil pressure sensor mine was pissing out under high rpm .
nestorlugo is offline
Old 10-27-2014, 03:33 PM
colt149's Avatar
[QUOTE="Chris Gregg;8995538"]
Right off hand I can't recall the figures, but always make sure these are set to INCH pounds and NOT foot lbs
Nissan recommended torque for the bolts of valve cover gasket is 60-84 inch-lbs or 5-7 foot-lbs
colt149 is offline
Old 10-27-2014, 06:37 PM
Get Off My Lawn
^^^----- Good. Thanks for posting both numbers. Couldn't recall numbers, but wanted to verify inch vs foot lbs. Mainly just because I made that mistake not paying attention - LOL!!
Old 10-27-2014, 10:08 PM
Bad *** Newb
Damn torque *****
1/4" ratchet "pretty tight" is plenty
Would you be frightened to know I did my engine swap without using a tq wrench except for rod bolts and the friction plate?
Old 10-28-2014, 07:55 AM
q.man06's Avatar
lol. Mine never leaked OR seeped a drop of oil for 100k miles, but it sure burned oil. 1.5 quarts every 3k at the beginning, then 3.5 quarts every 3k at the end when the engine died from oil pump failure at 207K.
Glad you fixed your oil leak.
The only solution to oil consumption is to rebuild or 5.7 gen it. With the 08 altima engine I don't burn ANY oil between changes
q.man06 is offline
fastcarny
05-18-2020 10:40 AM
fastcarny
08-12-2015 03:50 PM
papo99
08-09-2015 07:24 AM
yat70458
08-03-2015 01:16 PM
Quick Reply: How to fix any 2002 - 2006 Maxima (3.5L) oil consumption/leak
