Coolant reservoir rattle
Old 10-22-2014, 04:51 AM
D.Stillwell's Avatar
Didn't wanna make new thread but clearly there is nothing on this anywhere..
So the coolant reservoir, stupid white plastic tank, rattles slightly. I've been trying to track this sound down for close to a year now and finally I found it.
The sound is very faint, you can only hear it when driving slowly over bumpy roads, and during quiet times like early morning or late night. But I can hear it, and I know it's there, it has been driving me nuts.
I tried to tighten the bolts a bit (without breaking) but that doesn't help. Just seems like a bad design and the bolts that hold it aren't doing anything, it still moves side to side (not up/down) very slightly and causes plastic rattle sound.
Anyone have any idea what I can do to completely secure this thing so it doesn't move?? I really have no good ideas right now for this..
help?
D.Stillwell is offline
Old 10-22-2014, 08:35 AM
Bad *** Newb
Child_uv_KoRn's Avatar
Put thin foam padding around it and bolt it back down.
Child_uv_KoRn is offline
Old 10-22-2014, 09:21 AM
Just checked mine (2000 Max) and it's solid as a rock. It does not move side to side. Only with moderate force can I get it to jiggle and rattle up and down. On mine, the rattle comes from where the male plastic piece goes into the female receptacle at the bottom. Where it's rattling, I imagine a small piece of dynomat or an old piece of rubber should do the trick. Even those circular dampener bumpers sold at Home Depot etc to prevent kitchen cabinet doors from slamming would do the trick.
The Wizard is offline
Old 10-22-2014, 11:58 AM
^ Thanks to you both for the suggestions.
Dont know why I didnt think of those things... I guess since its already rattling with the bolts dead tight I figured mayde I needed a stronger reinforcement..
Im gonna try putting some kind of padding on it, hopefully I can pinpoint where its hitting the frame too.
Seems like the rattle is just from the mounting points cuz the bolts dont hold tight enough (mayb got a bit loose with age)
hcarter1112
42
07-18-2022 03:35 PM
Miket2006
03-01-2021 03:55 AM
msellas
09-23-2015 09:16 PM
jerrod99_se-l
09-16-2015 02:39 AM
NissanNismoZ
09-12-2015 07:30 AM
Quick Reply: Coolant reservoir rattle
