Seized jam nut
Old 09-25-2014, 10:00 AM
2damax's Avatar
Seized jam nut
Hey guys, I have a small issue. I replace my outer tie rods a couple weeks ago. I noticed the driver side jam nut is seized to the inner tie rod. I just replace my tires and I cannot get an alignment on that wheel since the nut won't spin.
I tried tons of PB and a benzomatic. Any other ideas?
Thanks in advance.
2damax is offline
Old 09-25-2014, 11:42 AM
Puerto Rico-Maxima Lover
Lontar1's Avatar
dremel the nut out, heat, or replace the inner and out again
Lontar1 is offline
Old 09-26-2014, 05:12 AM
2damax's Avatar
Is the heat from the benzomatic enough heat? The other options you listed are more of a last resort for me.
2damax is offline
Old 09-28-2014, 06:16 AM
Max_Gator's Avatar
If you can get the outer tie rod off, you should be able to get a nut splitter onto that nut. Can find them at sears or auto parts stores.
Max_Gator is offline
Old 09-28-2014, 09:48 AM
2damax's Avatar
^ thanks. That is what I am doing my next day off.
2damax is offline
Old 09-28-2014, 09:56 AM
CMax03's Avatar
If you get it off The threads wiil be so messed up you'll have to replace both anyway! GL!
CMax03 is offline
Old 09-28-2014, 10:02 AM
2damax's Avatar
Are you sure? That would really suck! Maybe I should just find someone with a real torch.
2damax is offline
Old 09-28-2014, 12:14 PM
Lontar1's Avatar
I would just replace both... saves time.. you can rent the tool to remove the inner one from Autozone, but thats just me
Lontar1 is offline
Old 09-29-2014, 04:48 PM
2damax's Avatar
Ok I decided to do this. I have not done an inner tie rod before. I read the autozone tool doesn't always fit perfectly. Anyone have recent experience?
Any tips for the job? Should I replace the boot too? I just put the tool on and twist it off and then twist the new one on with a drop of blue Loctite right? I don't want any surprises.
2damax is offline
lowpost99
05-16-2021 11:18 AM
coolsun
Wheels/Tires
11-13-2016 05:01 PM
knight_yyz
11-01-2015 01:34 PM
camako
09-22-2015 04:27 PM
Quick Reply: Seized jam nut
