Energy suspension or OEM mounts
Old 09-14-2014, 07:52 PM
MaxinO2's Avatar
Hello, so I'm about to replace the engine and tranny mounts and was looking for advise on these two. I want the smoothest ride since I live in colorado and the roads suck. Which for smoother ride?
MaxinO2 is offline
Old 09-14-2014, 07:57 PM
Fakie J Farkerton's Avatar
Oem.
Fakie J Farkerton is offline
Old 09-15-2014, 12:24 PM
MaxinO2's Avatar
Wow, I called the dealership and they want almost $700 for all 4 mounts. Looks like I'll be going somewhere else.. If anyone knows a good place to get OEM aftermarket mounts please list it. thanx
MaxinO2 is offline
Old 09-15-2014, 01:10 PM
Donkeypunch's Avatar
Go on amazon or ebay.
I bought a set maybe a year ago and they
where unbelievably cheap.
Donkeypunch is offline
Old 09-15-2014, 05:22 PM
TallTom's Avatar
Beck/Arlney brand. OEM quality at half the price.
TallTom is offline
Old 09-15-2014, 05:33 PM
cornholio's Avatar
ebay like $100 for all 4. are the tranny mounts worn? i thought those usually held up better
cornholio is offline
Old 09-15-2014, 05:56 PM
greaseyoda's Avatar
screw ebay go to rockauto.com
greaseyoda is offline
Old 09-15-2014, 05:57 PM
Bad *** Newb
Child_uv_KoRn's Avatar
ES or window weld the old ones. Stock is just junk.
Mounts do not affect ride quality. They keep the chassis from vibrating slightly at idle. Big ****in deal.
If you haven't noticed the engine is silky smooth when not at idle (it is an internally balanced V6). :P
Maybe nissan says otherwise LOL. You can't feel a difference.
Child_uv_KoRn is offline
Old 09-15-2014, 07:41 PM
TallTom's Avatar
Ebay ones will fall apart within a year. Been there, done that. The rubber is too soft.
TallTom is offline
Old 09-15-2014, 07:50 PM
cornholio's Avatar
got about a year and a half on mine so i guess i better watch out lol
Old 09-15-2014, 08:11 PM
Puerto Rico-Maxima Lover
Lontar1's Avatar
i replaced all 4 of them over 2 years ago and they are broken again. I can feel the shake when changing the from P to R or D, but other than that... I'm not replacing them again. The car on idle is way too smooth to believe the motor mounts are gone
Lontar1 is offline
Old 09-16-2014, 09:27 AM
barristan's Avatar
If you go the ES route make sure you have access to an arbor press or a blow torch. The OEM rubber/metal mess was a PIA to get out with just hand tools.
barristan is offline
Old 09-16-2014, 11:17 AM
WTF?'s Avatar
I got Ebay for less than 100 shipped for all 4 of them. They are fine.
WTF? is offline
Old 09-16-2014, 12:50 PM
I would only get ebay to poly fill to save some downtime.
And yeah, $700 for OEM
ES makes a DIYMMI kit to pour your own and fill it. Cheap too.
Old 09-16-2014, 03:57 PM
MaxinO2's Avatar
Thanks for all the comments,
my cars vibration is real ruff at idle and now when I accelerate I get some vibration. The more gas I give it the more vibration. I've had several people tell me that bad moter and tranny mounts can cause this. Correct me if that's not true.
I mean I guess it could be the new axle on the passenger side causing this too. Vibration started shortly after the axle install.
In the mean time I've completely re-done the suspension.
Both axle's, end links, tie rods, wheel bearings, ball joints, brakes, roters, new tires and only 70k on engine.
MaxinO2 is offline
Old 09-16-2014, 07:50 PM
TallTom's Avatar
Is your car auto or manual trans? And what brand axles?
TallTom is offline
Old 09-18-2014, 03:49 PM
MaxinO2's Avatar
It's a manual and the axles I got were from Advanced auto, Tough one is the brand.
MaxinO2 is offline
Old 09-18-2014, 05:32 PM
ac max 92's Avatar
Go with the ES and you probably wont have to worry again being their polyurethane and resistant to oil and salt etc. and are a good solid bushing. Most of your ride quality is going to be in your suspension. Shocks and struts etc.
ac max 92 is offline
Old 09-18-2014, 10:11 PM
george__'s Avatar
OEM
oem
oEm
OeM
OEm
oEM
oeM
george__ is offline
Old 09-19-2014, 04:39 AM
The_Fixer's Avatar
George went you supposed to go away or something? Your opinions and reviews should come with a disclaimer: I'm Canadian and i crashed my car in the back of a truck while texting and have Failed at every Mod on this forum!
The_Fixer is offline
Old 09-19-2014, 06:55 AM
dot dot dot ...
NmexMAX's Avatar
I think the reason OEM was so $$ is because they're not inserts, unlike the ES, they include the entire mount, which I'm sure you don't need. I agree, suspension is where it's at and tires/wheel size. If you're on stock 17's, go with 235 50's.
BTW, NM roads are worse than CO roads.
Or: https://maxima.org/forums/supercharg...or-mounts.html
NmexMAX is offline
James92SE
142
01-02-2024 09:23 AM
-ReLLiK-
04-29-2016 06:25 PM
240tomax
09-13-2015 03:28 PM
spidgeon
09-09-2015 03:36 PM
Violator
09-09-2015 10:14 AM
Quick Reply: Energy suspension or OEM mounts
