How to tell if/which coil is bad?
How can you tell? I have a 2002 Nissan Maxima with a P0300 diags code. I'm going to switch out the spark plugs (they are like really old @ 132,000). But someone suggested that I get the coils changed. I really don't want to spend the $300+ on the coils right now. So if it happens just to be one....how can I tell?
Until the ECU throws a specific code there is no way to know which one it is. You can get a new coil and start swapping it from cylinder to cylinder to see where it is going to make a difference, but that involves more work.
I have been getting that code every so often for the last 3 years, car always feels great never felt a misfire but p0300 always comes back, after 3 years I finally got a code for cylinder 6 misfire, I swapped in a new oem coil car still feels great I hope that was my problem.
Ok .any codes?..since you have to remove the manifold to access bank 1....I'll just buy some cleaner and coil grease to refurbish you coil boots in case they have corrosion build up on the spring,since you dont want to do the job twice , if you trigger a misfire code after removal and installation,
since you don't have any codes or funds I'll say leave 'em.
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
Andy29
09-29-2015 05:32 AM
