Groaning rotational noise under load, 01 Automatic
Old 08-06-2014, 04:53 PM
Blown
cardana24's Avatar
Hey guys,
On my 01 Anniversary edition I am having a groaning rotational noise that happens under load. Like when I goose the gas pedal or try to accelerate quickly. It does not happen if I accelerate slowly, and it will go away while I am just cruising at speed and it does not happen in reverse. I thought it was axle related so I change both of my axles....no change. The only thing I found when I was searching was that the 6th gens have an issue with a noise under acceleration that is related to broken exhaust shields. Does any one have any experience with this? At this point the car is stock except the y pipe. I am thinking I will swap back to the stock y pipe just to rule that out. Any ideas??
cardana24 is offline
Old 08-07-2014, 05:50 AM
Blown
cardana24's Avatar
I should also add this seemed to happen once I lowered the car. Before I lowered the car I did not have this noise, but as soon as I lowered the car the noise was there. I also did the y pipe around this same time (I can't remember if they were the exact same time or within a few weeks of eachother). So I assumed when I raised the car the noise would go away. When it did not go away, I assumed I trashed the axles while it was lowered. So I replaced both axles with new napa axles, and nothing changed.
Old 08-07-2014, 10:24 AM
Puerto Rico-Maxima Lover
Lontar1's Avatar
same issue I have with my 01. The noise is the tires that are going bad, no matter what you do to the alignment, the noise will be there. It happens when you lower your car. Try swapping tires with another car just to rule that out. Hope this helps.
Lontar1 is offline
Old 08-07-2014, 10:27 AM
Blown
cardana24's Avatar
Thanks for the advice but that is not my problem. I have put 3 different sets of wheels and tires on the car and the noise is exactly the same on all of them.
jmlee44
10-02-2022 02:13 PM
hcarter1112
42
07-18-2022 03:35 PM
D Mason
06-21-2016 04:43 AM
Andy29
09-29-2015 05:32 AM
Quick Reply: Groaning rotational noise under load, 01 Automatic
