03 Maxima stalls after a few minutes and won't run
The other day I was driving home and my 03 Maxima started bogging down and finally stalled. I had it towed home. After it cools down it will start, run beautiful, and only run for a few minutes and then stalls. I have no trouble codes. I pulled off the fuel line under the back seat and it sprays fuel when I turn the key......any thoughts were I look or test next? HELP!!!!!!
Just an update.....I finally pressure tested the fuel line and guess what.....NO PRESSURE. just because I pulled the fuel line and fuel sprayed out when I cranked the motor does not mean that I have the required 43 PSI to run the car. I replaced the fuel pump and as good as new! thanks
kjlouis
11-24-2018 06:09 AM
