Headers installed
Old 07-18-2014, 07:17 AM
barristan's Avatar
Headers installed
As you may know I have a set of headers and was planning on installing them myself. It looks pretty daunting considering I can't even see most of the bolts.
I decided to start with just gutting the precats. Baby steps..
I am able to remove the front precat pretty easily without removing anything else. I removed all of the bolts just to see if I could. I put it all back together. I may have to go to Sears and pickup a oxygen sensor wrench. I don't have anything small enough to fit in the space as-is and there doesn't appear to be enough slack with the wire to drop it down and remove it.
I know the rear is going to be more of a pain.
barristan is offline
Old 07-18-2014, 11:45 AM
barristan's Avatar
it looks like getting the bolts and oxygen sensor off was the easy part. It seems to be rust-welded to the flanges. I tried breaking it loose with a hammer but still no-go.
I removed 4 bolts between the precat and manifold and 3 bolts going to the y-pipe. It looks like that's all I have to remove.
Any suggestions?
Old 07-18-2014, 12:34 PM
barristan's Avatar
2 more nuts going in from the top.
Old 07-18-2014, 12:43 PM
barristan's Avatar
I've got all the nuts and bolts removed and it's not rust seized ( I can see the separation), I can move it a little but it's still won't come out. What am I missing?
I'm beginning to see why people say just install headers. The thing still doesn't want to break free.
The manifold nuts looks pretty clean.
Old 07-18-2014, 06:51 PM
barristan's Avatar
Could OP please rename the thread to "help me get this precat off"?
Old 07-18-2014, 07:04 PM
tosheto's Avatar
The front manifold should be bolted to the engine with 6 14mm nuts and then 3 bolts/nuts (can't remember which ones) on the bottom. Then you can take it out. The back one us similar: 6 nuts on top, 3 on the bottom. I assume the rear one will be the hard one. The time I messed with those I had the engine out, so it was easy for me.
tosheto is offline
Old 07-18-2014, 07:37 PM
barristan's Avatar
I'm still trying to remove the precat only. I removed 4 bolts going in from the bottom and 2 nuts on the top and the three that connect the y-pipe.
Old 07-19-2014, 08:20 AM
barristan's Avatar
Based on the number of views and no replies I'm guessing it should have just fallen down after I removed the 7 bolts and 2 nuts.
Old 07-19-2014, 09:03 AM
ateick's Avatar
Is this the one you are struggling with? If you have all the bolts and nuts off you probably just need to use a hammer to get it to detach.
ateick is offline
Old 07-19-2014, 10:21 AM
barristan's Avatar
Wow! you've got a lot of rust there. Yeah, it looks like that and it looks like I took off all the nuts/bolts. Maybe that lip on the top piece is holding it in. I did bash the hell out of it with a pipe but the damn thing didn't want to move.
Thanks for the pic.
Old 07-19-2014, 10:30 AM
Bad *** Newb
Child_uv_KoRn's Avatar
Have fun gutting the rear LOL It took me 3 hrs on one.
Child_uv_KoRn is offline
Old 07-19-2014, 11:03 AM
barristan's Avatar
Did the front one fall off after you took out the nuts/bolts?
Old 07-19-2014, 12:07 PM
ateick's Avatar
Thanks for the pic.
Crazy rust on the car I took this off. The lower rad support wasn't even there practically. The front of the motor was just hanging in air. Good old Canadian winters.
ateick is offline
Old 07-19-2014, 12:50 PM
Bad *** Newb
Yep. I bet it's missing some mass, too from rattling around (getting sucked back up). How clogged were yours? I couldn't see through the ones I did LOL
POS cats
Old 07-26-2014, 08:05 AM
barristan's Avatar
someone could have told me that I couldn't just remove the front precat by itself. I pried a small gap between the flange from the precat and the y-pipe and noticed some sort of gasket. Not a flat gasket, but one that goes inside the holes and is holding them together. No wonder the thing wasn't budging. Do I have to remove the whole y-pipe to make enough slack?
Old 07-26-2014, 10:20 AM
barristan's Avatar
Okay, here's the deal: To gut the front precat you need to remove the three nuts (in my case two of the bolts came off with nuts attached) from the rear precat. You also need to remove two bolts between the front and rear precat that hold the y-pipe to the frame. After that it should come out easily (no bashing required).
Anyway, the gutting was pretty easy. If you were so inclined you could probably get the whole mess out in one piece. It only took 15 minutes or so to clean it out. Wear a mask.
Put it all back together.
In the near future I will do the rear. Or maybe after I get the rear off I will just go ahead and install the headers.
Old 07-28-2014, 05:02 PM
Leroni35's Avatar
What did you use to gut the precats? I mean tools wise.
Leroni35 is offline
Old 08-09-2014, 07:51 AM
barristan's Avatar
Sorry I missed your question.
I only gutted the front. I just used a screwdriver and a wire brush. The front is pretty fragile so it's easily removed. Once you pull out the majority of it there is some fabric type material(probably asbestos or some other noxious material). I used the wire brush to scrub it out. I did wear a good respirator.
As far as the back goes it looked to be not much more trouble to install the headers. So that's my plan.
I have been working on that this weekend. I'm done for now thanks to a 10mm bolt on the rear heat shield. If I could have got that one out I probably could have finished the job without much trouble. It's the center one. What a PIA. I tried from up top and down below. Under the car seemed to be the most promising. I got a socket on it a couple of times but I don't think it was at the perfect angle and it slipped.
Thinking about taking it to a shop to see if they can reach it from the top.
Old 08-09-2014, 12:05 PM
ateick's Avatar
Question for you Barristan or anyone that has done this...did you put the heat shields back on? Mine are destroyed. Wondering if there are heat issues without them.
ateick is offline
Old 08-09-2014, 12:37 PM
barristan's Avatar
Header install removes the heat shields. So I'm guessing it's not really a big deal if you don't have them.
Old 08-09-2014, 02:49 PM
D.Stillwell's Avatar
^^ Actual cats run hotter than gutted cats or headers, heat shields aren't really a big deal. I still put mine back on after cleaning em up and getting the surface rust off.
D.Stillwell is offline
Old 08-09-2014, 05:09 PM
blue_strip's Avatar
Ok, I'm really considering doing this now, can some one post what this job accomplishes and also the work involved? I have never really understood the point of gutting
blue_strip is offline
Old 08-10-2014, 05:56 AM
ateick's Avatar
Gutting is akin to headers without the cost. Basically remove the two precats, remove the material inside them which increases flow and prevents the possibility of them failing and breaking up on their own and then reinstall the precats.
Be warned though its not a fun job.
ateick is offline
Old 08-10-2014, 11:31 AM
Donkeypunch's Avatar
So you need to drop the exhaust to get the cat out?
Might as well do the rear then.
Donkeypunch is offline
Old 08-10-2014, 12:12 PM
barristan's Avatar
It depends. For the front all you need to do is loosen the exhaust just enough to make room for the lower gasket on the front precat to slide out (about an inch). It's not a flat gasket like the one at the main cat.
The rear would be a major PIA. The biggest problem is the heat shield on the precat. There are three 10mm bolts. Two are fairly easy to reach but the center one is a bear.
Old 08-10-2014, 02:39 PM
blue_strip's Avatar
Awesome thanks for the help! Going to do this one of these days when I get a chance and it's bellow 110 outside
Old 08-15-2014, 02:17 PM
barristan's Avatar
O2 sensor issue
Got my headers on! Finally.
Now, I have issues with a couple of the O2 sensors. The wire are too short and the connectors are melting.
Can I buy extender cables?
[IMG]P1000391 by Barristan, on Flickr[/IMG]
Old 08-16-2014, 03:22 AM
Prophecy99's Avatar
i would say yeah, especially since they make O2 sims with wires etc.
nice work, what are you impressions after gutting precats vs actual headers?
Prophecy99 is offline
Old 08-16-2014, 07:23 AM
The_Fixer's Avatar
Got my headers on! Finally. Now, I have issues with a couple of the O2 sensors. The wire are too short and the connectors are melting. Can I buy extender cables? [/URL]P1000391 by Barristan, on Flickr[/IMG]
Darren Surratt makes extended harnesses.
The_Fixer is offline
Old 08-16-2014, 10:08 AM
Fakie J Farkerton's Avatar
I've got a couple I don't need I got with my cattmans.
Shoot me a PM if ya want.
Fakie J Farkerton is offline
Old 08-16-2014, 10:46 AM
barristan's Avatar
Thanks, but I went ahead an extended them myself.
Old 08-16-2014, 10:58 AM
Old 08-17-2014, 10:21 AM
barristan's Avatar
My first impressions:
1) It smells like hell. The heat wrap is still curing. It smoked for a good 30 minutes.
2) It's definitely more noisy. There is a rumble when letting off the gas and coasting.
3)I think I may have some rubbing issues to work out. I have been avoiding winding it up too much due to the rubbing.
4) It seems like the engine bay gets a lot hotter now.
5) I still need to fix the ghetto weld job.
[IMG]P1000396 by Barristan, on Flickr[/IMG]
Old 08-20-2014, 10:58 AM
dot dot dot ...
NmexMAX's Avatar
Headers ftmfw~!
NmexMAX is offline
Old 08-21-2014, 07:37 AM
Prophecy99's Avatar
thanks for the feedback.
is that a fast cat after the headers? and can you notice any power improvements vs the gutted precats?
Old 08-21-2014, 02:23 PM
barristan's Avatar
No, the cat is factory as far as I know.
I only gutted the front, so it's not a good comparison. Gutting the front seemed to free up a few hp and gave a slight grumble (barely noticeable).
With the headers I've freed up much more hp and the grumble has gotten more noticeable. I usually cruise around 80mph to and from work(major highway) and now it feels like the car is working much less to maintain that speed and it still wants to pull. I really like the grumble when coasting at +2500 rpm.
I'm so happy with the headers that I feel the need to take it to the track again this weekend and try not to finish off my clutch (next project).
Old 08-22-2014, 05:07 AM
95VQ30's Avatar
95VQ30 is offline
Old 08-22-2014, 04:05 PM
barristan's Avatar
#$@#%# clutch!
R/T .417
60' 2.879
330 6.838
1/8 10.093
mph 76.26
1000 12.871
ET 15.341
mph 90.18
Old 08-27-2014, 03:19 PM
ateick's Avatar
I have the rear heat shield unbolted. How have people removed it. The last one I did was in such poor shape it fell apart and was flexible enough to pull out. This one is solid and catches on everything - everywhere.
ateick is offline
Old 08-27-2014, 03:54 PM
Tin snips.
Quick Reply: Headers installed
