Scrapping Noise when turning
Old 07-01-2014, 12:58 PM
boondoxmax's Avatar
I have this weird scraping noise when I make right turns. Not the clicking noise you get from bad axles. Like metal scraping together. I goes away once the wheel is straight. Buddy of mine thinks its the control arms.
boondoxmax is offline
Old 07-01-2014, 01:53 PM
homeyclaus's Avatar
I just fixed that on mine, it was corrosion on the disk brake heat shields/backing plates. Especially if you lift the front of car up, turn the wheels, and hear nothing.
homeyclaus is offline
Old 07-01-2014, 06:30 PM
ajahearn's Avatar
Also check your bearings.
ajahearn is offline
Old 07-01-2014, 11:19 PM
5th Gen till she dies!
ManualMaxima's Avatar
+1 Same problem awhile ago and that was my issue. To confirm jack offending side up, grab your tire and push/pull it feeling for any play. If it's solid, you've generally at least just ruled out the most common cause.
ManualMaxima is offline
Old 07-04-2014, 07:19 AM
1996blackmax's Avatar
This is what I was thinking.
1996blackmax is offline
Old 07-09-2014, 06:18 PM
boondoxmax's Avatar
I thought bearing made a humming noise while driving. This is a scraping noise.
Old 07-09-2014, 06:56 PM
Both are symptoms. Mine made a bad scrapping noise back when...
Old 07-10-2014, 06:43 PM
dcam0326's Avatar
If it's when you're turning I would almost guarantee its those damn heat shields behind the brakes. I took a flathead and covered it with a towel and wedged it in between the inner side of the disc brake and the heat shield on the lower side and the problem has been solved for months. It keeps recurring though and I just have to keep repeating it. I might actually be doing it again tomorrow if you need pics of what I'm talking about.
dcam0326 is offline
Old 07-11-2014, 09:28 AM
boondoxmax's Avatar
Yeah I am thinking that's the case. My car sits a lot cause I have a company vehicle so I am sure rust builds up a lot.
Old 07-22-2014, 05:47 PM
boondoxmax's Avatar
It was the control arms. Both replaced and scraping noise gone.
Old 07-22-2014, 05:58 PM
Good, always nice to see someone post a conclusion. Glad to see your rides back in working order...
pears
09-18-2015 05:25 AM
lrb6805
09-17-2015 04:49 PM
LtLeary
09-14-2015 12:33 PM
thenewguyy
09-12-2015 11:12 AM
ballerchris510
09-11-2015 05:29 PM
Quick Reply: Scrapping Noise when turning
