Strange B pipe gasket isssue
Old 06-24-2014, 09:40 AM
Domf3's Avatar
I purchased a dynomax resonator and muffler for my 2001 Maxima. I used the following diagram: http://www.rockauto.com/catalog/more...600&cc=1374533
Everything lined up perfectly except the gasket that goes between the B pipe and resonator (part 31374 in the diagram). Any ideas? My mechanic retrofitted a temporary gasket but I'd like to use the correct part because its leaking a bit.
Domf3 is offline
Old 06-24-2014, 09:42 AM
dot dot dot ...
NmexMAX's Avatar
What's the issues? too big, too small, holes don't line up with the flanges? These things are pretty universal.
If anything, go get one at Nissan, they used good gaskets.
NmexMAX is offline
Old 06-24-2014, 01:35 PM
Suspension Yoda
djfrestyl's Avatar
IIRC the OEM gasket is not just a flat gasket. It's that shape, but also has an integrated thick circular ring where the tubes connected as they're beveled on the inside, not just flat.
djfrestyl is offline
Old 06-24-2014, 08:27 PM
Domf3's Avatar
No holes, it was just a ring type gasket. It was too big. ID was 2 -1/4 but the size of the pipe is 2"
Strange right?
Domf3 is offline
Old 06-25-2014, 05:35 AM
The_Fixer's Avatar
Originally Posted by Domf3
No holes, it was just a ring type gasket. It was too big. ID was 2 -1/4 but the size of the pipe is 2" Strange right?
That is called a crush gasket it is used in between the OEM axleback and B pipe if you have a aftermarket exhaust part there you need a regular 2 hole gasket
The_Fixer is offline
tarun900
19
12-20-2021 06:57 PM
06-06-2017 02:01 PM
Quickywd01
09-21-2016 09:36 PM
knight_yyz
11-01-2015 01:34 PM
Quick Reply: Strange B pipe gasket isssue
