2000 maxima misfire
Old 03-29-2014, 09:53 AM
rjbrown87's Avatar
2000 maxima misfire
My car misfires I don't think it's the coils..... Whenever I wiggle the black wire that's connected to the ignition coil connector on cylinders 3 and 5 it misfires.... The wire has to be at a certain position not too misfire I hope this make sense can someone help me???
rjbrown87 is offline
Old 03-29-2014, 09:57 AM
FallenOne's Avatar
The coils on the 00-01 were essentially recalled.. Unless you have A Grey Dot on top of all your coils they are probably junk and need to be replaced. Ive been running the old ****ty coils for a long time now, ive just been waiting to come across a set of grey dots at the bone yard.
FallenOne is offline
Old 03-30-2014, 06:44 AM
rjbrown87's Avatar
I changed coils 3 and 5 still misfires
Old 03-30-2014, 08:03 AM
blue_strip's Avatar
I'd say you might have a bad wiring harness on yours, the fact that the wire has to be in a certain position leads me to believe that one of the wires is broken or has become seperated
blue_strip is offline
Old 03-30-2014, 02:29 PM
DennisMik's Avatar
Originally Posted by FallenOne
95-98 FSM Still Works 08/01/13
Your description for the FSM in your link is wrong. The FSM in the link is for the 1998 Maxima. It is only accurate for the 1998.
Every year of the 4th gen Maxima has a different electrical system. The 95 and 96 are close (but not identical) to each other. The 97 and 98 are close (but not identical) to each other. If you followed the 98 FSM for an electrical problem on a 95 or 96, you could cause some serious damage. If you were working on a 97, the differences are much less.
Essentially the EC and EL chapters are the biggest dangers for using the wrong year FSM. The mechanical stuff is pretty much the same.
If you want to provide a link to the FSM, I would like to suggest either of these two:
http://boredmder.com/FSMs/Nissan/Maxima/
http://www.nicoclub.com/FSM/Maxima/
DennisMik is offline
halfpol
10-17-2022 12:16 PM
Balkins
08-12-2015 06:39 AM
jholley
08-11-2015 09:38 AM
niZ
08-07-2015 10:18 PM
yat70458
08-03-2015 01:16 PM
Quick Reply: 2000 maxima misfire
