torque pressure sensor
New mechanic I got for my car..
Maybe I got the part wrong... I will confirm. Usually it's something located on the pedal but our cars are different.
Throttle position sensor
Well, it's located on the throttle body so I'd have to buy the whole part anyways. I might as well, I'll pull the code once I get back home but most likely.
Also the clutch sticks to the floor lol, I think it has a air leak.
I'm getting a price of 600 bucks for it, I just need the throttle body, someone post a link from a good website to buy from? and do I need oem or aftermarket?
www.car-part.com
www.nwpengineering.com
www.courtesyparts.com
www.rockauto.com
www.thepartsbin.com
I thought it was included in the throttle body but it seems to be sold seperate.
http://www.partstrain.com/store/??N=...universal:0%29
I'm getting 420 and 430 codes...
Resoantor wont do you any good.
http://www.courtesyparts.com/22620-t...ml?cPath=1956&
$16 cheaper here:
Thanks, I'm debating buying only the switch vs the refurbished tb and swith? Isn't it possible to just clean the throttle body without having to change it?
Also, I want to get rid of the cat, it's factory and never been changed, what's the cheapest way to do this while limiting the noise? My mechanic says take it to a muffler shop, remove it and install a resognator but someone on here told me that's a bad idea.
Test pipe?
If your car is an 2002, then yes, the TPS/APPS will definitely throw you a code. And it would go into limp mode of the voltages aren't within a certain range of each other and you wont be able to break 5 MPH.
Also, not sure why you want to do the test pipe. I've seen cats las a long time. It' more so your pre-cats that will cause problems.
What's your car idling at now?
JoshG
51
09-21-2015 10:41 PM
RWCreative
09-21-2015 11:01 AM
