What tools are needed to install the bank 1 upstream sensor?
The bosch 13968 sensor. I have the o2 sensor tool but I can't get the proper position to take off the sensor, it's the one right in front of the firewall right behind the engine.
Yea, it's a pita because it's angled in and it's behind the engine, I tried to get to it from the top and I can't position the O2 sensor tool around it properly so I stopped in fear of stripping the sensor.
I'm gonna try from underneath the car tomorrow.
Not this ^^^^.
I could only get to my o2 in the rear manifold from the top with the manifold still bolted to the head... I think the o2 has to be out to remove that rear manifold though.
If it won't turn at all, then you've got a major pitmfa. The o2 socket with the slit out of it should go on even if you have to tap it on with a hammer.
I also antisiezed the threads when reinstalling.
I did mine from under the car, it was NOT fun. I used a combination of crowsfoot wrenches, along w/ a socket o2 wrench, and a big ole' hammer. But to make the job easier or not as much of a pita, is to have more than one length of o2 socket extension. It takes a lot of patience as well!
Did you get it?
kjlouis
11-24-2018 06:09 AM
TonyJr
08-20-2015 12:14 AM
MaximaDrvr
08-19-2015 08:20 PM
