VIDEO: possible engine knock? please watch
http:// https://www.youtube.com/watch?v=lBjVXJdeStQ&feature=youtube_gdata_player
OK so I noticed this noise on my car, all fluids are good, I just recently changed my oil and oil doesn't burn on my 2001 maxima AE, is this normal? Or could it be spark plugs probably, because spark plugs need to be changed, but I hear this noise by the timing chain area, but I put a screw driver on the cover to hear something, but couldn't hear anything at all. I noticed my friends 3.5 makes a very similar sound. If you guys could please help me out
That does not sound like timing chain noise. Timing chain or broken guides sounds a lot different. Did you check to make sure all your plugs are tight. It sounds like maybe exhaust leak off the manifold. Its really hard to tell just from the audio.
I have not checked the plugs, but if a plug was loose wouldn't it give me a misfire?
I know what you mean, how could I see if I had an exhaust leak on the manifold? Also could it damage the engine? Sorry if my questions sound stupid
You need to inspect it. Its hard to inspect the mainfolds because of how tight it is and where they are located. If you have a small leak, its not going to damage the engine, but it will turn into a bigger problem and noise.
If it is a timing chain guide, then for the time being its not going to do anything to your engine, unless the chain jumps or slips. It really depends on what part of the guide is broken.
Well I took the car too two mechanics plus a Nissan dealer and they all said the same thing, that it sounds like a normal engine, but to me it just doesn't sound normal, I have heard other maximas on YouTube and can't really hear that sound? So what do you think, I'm I just over stressing?
I don't think you're over stressing. I'm definitely hearing abnormal engine noise. I listened again. I'm still hearing timing chain noise. Behind it is something else, like lifter noise. It is possible you have a bad hydrolic lifter.
My recommendation is to do an oil change using Rotella 5w-40 T6 oil. It's deisel, but its fine for our cars. It eliminated 75 percent of my recently developed chain noise when cold and about 90 percent in warmer weather (65+ degrees). However, I understand.....as shoud you, that this is not a solution, rather a band aid for worn chain tensioners/guides that need replacing.
I'm curious if even your background tok-tok-tok is connected to the loose chain. Do an oil change and see what can be weeded out. I guarantee the chain rattle will be reduced within 100 miles.
Check your pulleys. Believe it or not, my idler pulley made a sound like the engine was knocking. It turns out, it was a few threads short of falling off from when I messed with the belts a few days prior.
We don't exactly have the most mannered engines on the planet either.
03-12-2020 12:06 AM
ballerchris510
09-23-2015 08:46 PM
ballerchris510
09-11-2015 05:29 PM
