Headlight Problem
Headlight Problem
I have a rather perplexing problem with my '00 Maxima SE, in regards my right headlight.
For years now, my high beam on that light has not worked. Recently, my low beam has also conked out. I assumed it was the bulb, but $50 later, realized it isn't.
I hooked up my volt meter. There are three wires to each light (bulb). At low beam, two wires should register 12V, and one none. Then with high beam, the non-voltage wire shows 12V, and one of the others goes to zero.
On the malfuctioning light, all wires show 12V? Is this a ground issue or a swich issue? Some help would Sure be appreciated!!
I know your from the great white north anf when I first got my car one of the solder points on the drl system circuit bored had melted off. All I did was reflow the solder and everything worked again. Have you taken a look at you drl module and opened it up??
Headlight
Could be a bad relay switch???? You may want to swap out one of your other relays in place of your possibly bad relay just to see. If you live near a pull a part auto salvage you could walk on site and pull one of these for less than $5. I think the relays for headlights are the most common relay we have under our hood so you should be able to pull one from something else to check.
If you decide you want to go the salvage route you may want to take your bad relay with you so you get the right one.
also if you go to Napaonline.com put in your year and model search for headlight relay you can click on the product you need then it will have a link on there for buyers guide which will give you every car the relay switch goes in so you dont have to find your generation maxima
here is a link
http://www.napaonline.com/Catalog/Bu...tNumber=AR6054
here is a link
The op is in Canada and those cars have a different headlight system because of the Canadian laws. Their cars have a DRL module (Daytime Running Lights) under the hood. You would have a good chance of being on the money if the car was a U.S. car. But with the DRL module, the relay is highly unlikely. Those DRL modules are a big headache for those guys.
AaronL
11-15-2020 11:52 AM
MaxLife17
06-27-2019 01:37 PM
03VQMAX
11-10-2015 03:39 PM
