Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 07-28-2013, 06:10 AM   #1
Points: 1,828, Level: 25
Points: 1,828, Level: 25 Points: 1,828, Level: 25 Points: 1,828, Level: 25
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
2000 Maxima GLE Idle issues
Hello, I have a 2000 GLE with 83000 miles. IACV was replaced at dealer about 6 months ago (79000) miles. Symptoms then were an erratic idle that was unsteady. Dealer advised that the valve was sticking, there was no coolant leaking that would cause a short and fry the ECU. Car has been running great until about 2 weeks ago.
Current symptoms are that the car will intermittently idle at 1000 - 1100 RPM when I come to a stop in traffic or at a red light. The idle is always steady, just not at 700 RPM where it should be.
When I come to a stop and idle is at 1000 - 1100 RPM and I put into Neutral, RPMs will surge to 1500 - 1700. When I come to a stop and idle is at 700 RPM (where it should be) and I put into Neutral, it stays at 700 RPM.
Is this a bad IACV, or is something else causing this. Could this be the MAF sensor??
Any help is appreciated. Thanks
billm is offline   Reply With Quote
Old 07-29-2013, 07:04 AM   #2
Points: 3,471, Level: 36
Points: 3,471, Level: 36 Points: 3,471, Level: 36 Points: 3,471, Level: 36
Activity: 1.8%
Activity: 1.8% Activity: 1.8% Activity: 1.8%
Did you scan for codes or pending codes? If no codes then I'd suspect the MAF over the IACV, maybe trying cleaning the MAF. You could if you want measure resistance of the 4 IACV coils, s/b 22 ohms. Might also check TPS adjustment, almost seems like the linkage might be sticking so it doesn't return to the stopper at idle. Does having a/c on affect the problem?
Pilm is offline   Reply With Quote
Old 07-29-2013, 08:48 AM   #3
Points: 141, Level: 2
Points: 141, Level: 2 Points: 141, Level: 2 Points: 141, Level: 2
Activity: 3.3%
Activity: 3.3% Activity: 3.3% Activity: 3.3%
I would clean or replace the MAF also. I recently had the same problem with my 2000 SE. I replaced the coils and plugs before reading the post on this site. I replaced the MAF with the part # 22680-2Y001 and found the Air Duct Hose had dry rotted with a hole at the clamp, letting air in to make the engine run lean. Runs and works great now!
cashman35173 is offline   Reply With Quote
Old 07-29-2013, 11:35 AM   #4
Activity: 0.8%
Thanks Cashman and Pilm. No codes pending or set, and yes the symptoms seem to occur more frequently when the AC is running.
I did replace the radiator myself around a month ago and I had move the air inlet assembly (on top of the upper radiator support) to get at the upper hose. I will check to make sure all hoses and clamps hooking into the air inlet and air box assembly are tight etc.
If all looks good, I'll replace the MAF. From what I have read on many posts, I will use OEM MAF.
I'll keep you posted on my progress. I'm on vacation this week and my 2000 Max was left at home.
Thx
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
